Need bios dump Dell Precision 5570
  • volinakis
    • Jan 2021
    • 2666
    • N/A
    #61
    Originally posted by johansel
    good day Could you help me remove the absolute from this team? S/N: H9Z2RQ3
    how many do you have? compare original against modified file and you'll figure out how to do it yourself...
    • johansel
      • Feb 2022
      • 34
      • colombia
      #62
      I apologize if I have already requested help many times to remove the absolute, I have tried to compare all the files to see a pattern with which to guide me and provide a solution on my own, however I have not been able to find said pattern
      since all the files have a change made in different lines of the code​
      • volinakis
        • Jan 2021
        • 2666
        • N/A
        #63
        no need to apologize, my question wasn't badly intended. So, you have to invalidate AbtState from VSS2 store for that open bios file with an hex editor and search for hex "410062007400530074006100740065" and change AA553F from above to AA553C. After that enter in bios setup and permanently disable Absolute.
Name:	Screen Shot 2024-10-30 at 02.11.04.png
        • johansel
          • Feb 2022
          • 34
          • colombia
          #64
          Thank you very much for the information, now I have an idea what to do.
          I really appreciate you taking the time to explain to me.​
          • johansel
            • Feb 2022
            • 34
            • colombia
            #65
            I just did the test with the instructions you gave me and it is indeed exactly as you indicated, now I can do it on my own without problems
            I really appreciate you guiding me​
            • volinakis
              • Jan 2021
              • 2666
              • N/A
              #66
              you are welcome.
              • bondminer009
                • Nov 2023
                • 48
                • Malaysia
                #67
                Good Day,
                Need your support, and advise for the solution related with my laptop
                Precision 5570 got condition : booting logo, and 2/3 second restart itself.
                Service Tag ; 6WX0DK3
                and I have question, is there any guide how to synchronize ME Cleaning if sample my case
                ME ; 16.1.25. 2128
                FIT ; 16.0.15.1624
                I used both side either FIT 16.1 series or 16.0 series got problem CSE error and cant continue.
                Appreciate for your support
                Salam,
                Three
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  #68
                  Originally posted by bondminer009
                  Good Day,
                  ME ; 16.1.25. 2128
                  FIT ; 16.0.15.1624
                  Salam,
                  Three
                  Try
                  • bondminer009
                    • Nov 2023
                    • 48
                    • Malaysia
                    #69
                    Originally posted by qayyum786
                    Try
                    appreciate, already tried. Still the same, logo appear and restart
                    • qayyum786
                      • Aug 2018
                      • 1933
                      • INDIA
                      #70
                      Try again
                      • bondminer009
                        • Nov 2023
                        • 48
                        • Malaysia
                        #71
                        Try again
                        still the same, now only dell logo 1 second and restart
                        • bondminer009
                          • Nov 2023
                          • 48
                          • Malaysia
                          #72
                          I downgrade the bios version and ME cleaning, unit working back
                          Attached for the file, tested working well
                          Thank you
                          • fergz
                            • Jul 2015
                            • 5
                            • Philippines
                            #73
                            Hi pls help me to fix and update bios region and clean me. thank you
                            ST: 3F6YHR3
                            • bondminer009
                              • Nov 2023
                              • 48
                              • Malaysia
                              #74
                              ST: 3F6YHR3
                              Try
                              Become a Badcaps supporter
                              Thanks to all supporters.
                              • jawal37
                                • Feb 2013
                                • 40
                                • afric
                                #75
                                Thank you
                                dump is good work for me 100/100 xps 15 9520
                                • ninsa
                                  • Dec 2018
                                  • 28
                                  • republica dominicana
                                  #76
                                  DELL PRECISION 5570
                                  ST: DW2SSV3
                                  EX:30237791007
                                  DOESN'T TURN ON AFTER A BIOS UPDATE​
                                  • amr soliman
                                    • Oct 2015
                                    • 116
                                    • egypt
                                    #77
                                    hello every one i have dell inspiron 5570 stuck at dell logo
                                    ​service tag B21B6W3
                                    this is the original 512mb chip file
                                    i dont know if its bios issue or not
                                    but i tried another file but still nothing logo comes with loud fans and after a while screen turn off whith logo in background
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11415
                                      • Viet Nam
                                      #78
                                      service tag B21B6W3
                                      Precision 5570
                                      Service Tag: B21B6W3​
                                      • amr soliman
                                        • Oct 2015
                                        • 116
                                        • egypt
                                        #79
                                        Originally posted by hoaca388
                                        Precision 5570
                                        it works perfectly big thank you
                                          DELL Precision 5570 Mobile workstation 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 5570 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5570 boardview and 5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                          09-07-2024, 06:40 AM
                                          09-07-2024, 06:38 AM
