Need bios dump Dell Precision 5570
  • johansel
    • Feb 2022
    • 37
    • colombia
    #41
    Originally posted by volinakis
    try. After write new bios at 1st boot enter bios setup Security-Absolute and disable it or permanently disable it.
    Good morning, test the new file, however the block is still present in the absolute
    What do you think can happen?
    It should be said that this equipment has several bios chips
    Do you think it is possible that additional information is housed in the other chips?
    • volinakis
      • Jan 2021
      • 2811
      • N/A
      #42
      reset bios to factory defaults, you wrote bios with CMOS battery connected
      • johansel
        • Feb 2022
        • 37
        • colombia
        #43
        thank you so much
        In resetting the factory bios it opened the option to deactivate the absolute
        I understood something new today and I thank you very much for that and the help you provided. ​
        • volinakis
          • Jan 2021
          • 2811
          • N/A
          #44
          thank you so much
          you are welcome, next time remember to disconnect CMOS battery
          • spacez
            • Nov 2023
            • 65
            • FR
            #45
            GOOD MORNING . I had a Dell xps 15 5570. with a damaged bios so I flashed another one from badcaps. pc starts but ssd is not detected and also error - tpm device is not detected -. I updated the bios but the problem is still there, please help me to fix that issue
            Service Tag: J2MSHW3
            |Express Service Code: 41518077843
            mother board LA-L402P REV 1.0(A00)
            • volinakis
              • Jan 2021
              • 2811
              • N/A
              #46
              wrong thread, this is for Precision 5570. And by service tag is a XPS 15 9520
              • spacez
                • Nov 2023
                • 65
                • FR
                #47
                ah thank you they are exactly the same.. same configurations same motherboard. in addition I didn't find a forum that talks about XPS 15 9520. I just followed the motherboard number..
                • volinakis
                  • Jan 2021
                  • 2811
                  • N/A
                  #48
                  you could open a new thread for your model. Don't you have original backup? This one you posted it is a old version (1.2.0) with clean ME firmware with 16.0 version, meanwhile Dell upgraded ME to 16.1 version.
                  • develop3302
                    • Sep 2024
                    • NA
                    #49
                    Can someone please help me locate the BIOS chip on the motherboard of a i9 12th Gen Dell Precision 5570? I can see a Winbond 25Q80DVIG on the board. But someone mentioned there should be a Winbond 25R512JVEN. Is that the BIOS one? Is it on the back of the motherboard?
                    • ZoOLf
                      • Mar 2021
                      • 61
                      • NA
                      #50
                      Yes its in the back
                      • develop3302
                        • Sep 2024
                        • NA
                        #51
                        Thanks for your reply
                        • johansel
                          • Feb 2022
                          • 37
                          • colombia
                          #52
                          good day Could you help me remove the absolute from this team? S/N: 35FWRQ3
                          • volinakis
                            • Jan 2021
                            • 2811
                            • N/A
                            #53
                            try. After write new bios enter bios setup and set Absolute to permanently disable.​
                            • bondminer009
                              • Nov 2023
                              • 48
                              • Malaysia
                              #54
                              Good Day,
                              Need help to check my dump file, I believe this is corrupted file
                              Precision 5570
                              ST : F6KD3J3
                              Condition of the laptop : Laptop On, appear Logo, then restart, and continuing logo and restart.
                              What I did are ME cleaning and manual copy from extracted bios (file 5570 hangOK), but once check via MEA cant check and blank / no information
                              original file (5570 hang)
                              Thank you for your great support
                              Salam
                              Three
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12132
                                #55
                                Originally posted by bondminer009
                                Good Day,
                                Precision 5570
                                ST : F6KD3J3
                                Salam
                                Three
                                Both files are corrupted.
                                ​https://www.badcaps.net/donate
                                • bondminer009
                                  • Nov 2023
                                  • 48
                                  • Malaysia
                                  #56
                                  Need help to get the new dump file. From that case
                                  • johansel
                                    • Feb 2022
                                    • 37
                                    • colombia
                                    #57
                                    good day Could you help me remove the absolute from this team? S/N: B853RQ3
                                    • volinakis
                                      • Jan 2021
                                      • 2811
                                      • N/A
                                      #58
                                      try
                                      • johansel
                                        • Feb 2022
                                        • 37
                                        • colombia
                                        #59
                                        thank you very much, I will try
                                        • johansel
                                          • Feb 2022
                                          • 37
                                          • colombia
                                          #60
                                          good day Could you help me remove the absolute from this team? S/N: H9Z2RQ3
                                            DELL Precision 5570 Mobile workstation 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 5570 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5570 boardview and 5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                            09-07-2024, 06:40 AM
                                            09-07-2024, 06:38 AM
