LG 12ZB990 key
  • Azbit
    • Jul 2021
    • Poland
    LG 12ZB990 key
    Hi everone,
    somebody have calculator to unlock key hint numer : E4368F35 ??
    LG 12ZB990 8th gen.
  • c0zmo
    Bios for Lenovo ThinkPad 10
    by c0zmo
    hi guys
    I have a Lenovo ThinkPad 10 which i am trying to update to windows 10 but unfortunately the bios is locked
    it shows an unlock key hint
    Unlock Key Hint Number:7F4155B4
    Any help to generate the unlock code to remove the supervisor password please
    Thanks guys​
    04-18-2025, 04:20 PM
  • AquaMan Ua
    Getac B300H bios
    by AquaMan Ua
    Hello Everyone.
    Need Help from people who are in the know, Who Can Generate Bios Password For Locked Laptop: Getac B300H.
    It Give 3 Try For Enter Correct Password And Hint For Unlock Key. Who Can Give Generated password/unlock Key For Bios?
    Unlock Key Hint Number F6E47152
    Serial Number: RBB51B0187
    If anyone has a BIOS dump for flashing it, please share it.
    Thanks in advance for your help
    12-03-2024, 11:12 AM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • carlitosbala
    Elektronika EPOS-73A stuck with fixed display
    by carlitosbala
    I'm hoping I can get some ideas on what to check in this old (1978) soviet-era electronic calculator I got from a flea market, the Elektronika EPOS-73A.
    Got it home and plugged it in. It worked just fine at first, I used it a few times for a few minutes each time, "kid with new toy" style.
    Then I disassembled it to clean the plastic case and the keys. I couldn't separate the lower half of the case from the board because cables are tied to it, so during the cleanup one of the cables going from the power board to the main board detached,...
    11-15-2023, 02:20 AM
  • totof
    Samsung UE55JS9000 backlight issue
    by totof
    Hello.
    I'm sharing with those in the know a problem I'm having with my Samsung UE55JS9000T TV, which has a backlight fault with halos of light on the sides (see my photos). This is a model with LED strip backlighting on the sides.
    I took the TV apart to remove the panel and noticed that the "yellowish" film on the Plexiglas light diffusion plate was stuck to the LEDs. When I peeled it off, it left marks on the Plexiglas plate, which I cleaned as best I could with rubbing alcohol (see photo).
    The result isn't perfect, but it still seems pretty good to me.
    10-05-2025, 08:27 AM
