HP Elitebook 840 G5 Endpoint Security Controller Problem
    • 20649
    Originally posted by arkolesz
    My MT45 has the same problem after removing the password. Can I ask for help in this thread?
    If its an Elitebook 840 G5 yes. https://www.badcaps.net/forum/troubl...before-posting
    • arkolesz
      • Sep 2024
      • Poland
      #42
      Ok, i got it. I will start a new thread​.
      • loris1987v
        • Oct 2013
        • 5
        • Italy
        #43
        good evening everyone, I need help, I have a problem with HP Elitebook 840 G5, with this error message on startup (hp endpoint security controller problem bios), I made a backup of the bios, I attach the file, thank you very much​
          • 20649
          Type and post the laptop serial number .... https://www.badcaps.net/forum/troubl...before-posting
          • loris1987v
            • Oct 2013
            • 5
            • Italy
            #45
            ProdID 2FA66AV
            Sn 5CG8327QHL
            thank you very much for your assistance
            • hoaca388
              Badcaps
              • Jan 2022
              • 11625
              #46
              ProdID 2FA66AV
              Sn 5CG8327QHL
              Endpoint security controller problem.
              • loris1987v
                • Oct 2013
                • 5
                • Italy
                #47
                perfect, thank you very much it worked, I reload a new backup because I still have some problems, I configured everything, but it still freezes on an MPM screen, I entered all the values ​​in the bios recovered from https://partsurfer.hp.com, not I understand how to pass this error
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11625
                  #48
                  HP EliteBook 840 G5
                  Serial_5CG8180LLR
                  Product_2FA66AV
                  Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAgdhKhk.hy
                  Build Id_17WWCSAT601#SABH#DABH
                  CT Number_6GPRKNCGWD106H
                  • loris1987v
                    • Oct 2013
                    • 5
                    • Italy
                    #49
                    HP EliteBook 840 G5
                    Serial_5CG8180LLR
                    Product_2FA66AV
                    You were fantastic, everything was resolved perfectly, great work, and thank you all
                    • sinan19
                      • Oct 2022
                      • india
                      #50
                      please help me
                      SN/-5CG9083C61
                      ProdID 5FE00UC#ACF
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11625
                        #51
                        please help me
                        SN/-5CG9083C61
                        ProdID 5FE00UC#ACF
                        • sinan19
                          • Oct 2022
                          • india
                          #52
                          NO DISPLAY
                          • mkatua
                            • Jul 2018
                            • 4
                            • Kenya
                            #53
                            HP 840 G5 no display. Kindly fix. Hope it will not bring security device error
                            S/N 5CG9262H4G
                            PN; 5TG90PC
                            • kolebbk
                              HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                              by kolebbk
                              Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                              HP Endpoint Security Controller problem
                              there is a problem with the hp endpoint security controller on the unit
                              I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                              09-04-2024, 12:44 AM
                            • fede77
                              Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                              by fede77
                              Notebook HP ProBook 450 G8
                              ProdID 2K8L1LT#AC8
                              Mother: DAX8QAMB8D0 REV D
                              The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                              03-10-2025, 07:12 AM
                            • lamonde
                              850 G6 Endpoint Security Controller Problem
                              by lamonde
                              Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
                              and there is no soud after flashing new bios, may be have some solutions?
                              ProdID: 4YD62AV
                              SN: 2TK9500V8X...
                              01-15-2025, 09:31 AM
                            • biednybelfer
                              HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
                              by biednybelfer
                              After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
                              Mainbard model:6050A3044201-MB-A01 (A1)​
                              Serial Number: 5CG0275ZLV
                              (I'm not allowed to upload files with the extension bin, so I upload zip)...
                              10-05-2024, 05:04 AM
                            • Voyager65
                              HP 800 G6 Deskop Mini - Endpoint Security Controller Problem
                              by Voyager65
                              I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
                              I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
                              SN: 8CC1120Z0V
                              PN: 8WY18AV
                              Bios Dump:
                              Thanks a lot...
                              01-13-2024, 04:58 PM
