lenovo thinkpad l14 gen 1
  • babydoll8867
    • Nov 2014
    • 91
    • romania
    #41
    Originally posted by Maxpower3
    you should look at my posts, once I made a file for L14/15, there was an error but he managed to enter the setup and do F9. but I don't know anymore or know
    I looked through your posts an didn't find anyone that said it worked... maybe i didn't look that good? has anyone succeed with the shorting method?
    • salawayon
      • Nov 2012
      • 572
      • philippines
      #42
      why so many changes in the file. it doesn't work with only 1 byte??
      thanks.. tried both files but the unit won't power up. it just power ON light and keyboard backlight then it just shut-off...
      • salawayon
        • Nov 2012
        • 572
        • philippines
        #43
        Originally posted by shiyab
        hi try
        tried and boot up became normal.. thank you so much....
        • Ghost18_07
          Zakaria
          • Mar 2018
          • 78
          • Algeria
          #44
          For me no, the shorting method didn't work. waiting for other solutions , and i'm still trying to solve it by mod the EC file.
          • rudienas
            • Apr 2017
            • 17
            • United Kingdom
            #45
            Can anyone unlock l14 Gen 1 (there is no files to be confirmed as working for NPCE68AP)
            EC dump Attached
            Don't know the serial as it is not provided on the bottom
            P.S was struggling to read with SVOD4 then comment above leaving the battery attached solved the issue, thanks Ghost18_07
              SMDFlea commented
              Editing a comment
              posts moved from L15 topic to L14 Gen 1
          • hoaca388
            Badcaps
            • Jan 2022
            • 11813
            #46
            EC dump Attached
            You have not extracted all SIO, please select 512KB.
            • rudienas
              • Apr 2017
              • 17
              • United Kingdom
              #47
              I do not have this option, 384k is the largest file I can read. Is svod4 not compatible with this unlock?
              • hoaca388
                Badcaps
                • Jan 2022
                • 11813
                #48
                You did not extract all the SIO contents.
                • rudienas
                  • Apr 2017
                  • 17
                  • United Kingdom
                  #49
                  can you explain how to do it. Not catching your phrase. Where is the rest content? Thank you
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1226
                    • France
                    #50
                    256k is enough,
                    384k file, the rest is a repeat of the beginning
                    file not cleaned ,just good size
                    • rudienas
                      • Apr 2017
                      • 17
                      • United Kingdom
                      #51
                      Thanks Maxpower3 for explaining can anybody clean or not?
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        #52
                        tonight,busy so far
                        • rudienas
                          • Apr 2017
                          • 17
                          • United Kingdom
                          #53
                          Thanks Maxpower3, you are legend
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1226
                            • France
                            #54
                            try maybe error
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1226
                              • France
                              #55
                              try maybe error
                              try those instead​
                              • rudienas
                                • Apr 2017
                                • 17
                                • United Kingdom
                                #56
                                Can confirm your unlocks give BAD SVP DATA.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1226
                                  • France
                                  #57
                                  you tried all 3
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1226
                                    • France
                                    #58
                                    retest them
                                    • rudienas
                                      • Apr 2017
                                      • 17
                                      • United Kingdom
                                      #59
                                      Sorry lost the hope paid on ******** for unlock. Thanks for helping me out.
                                      • Tians
                                        • Mar 2025
                                        • 4
                                        • ph
                                        #60
                                        Originally posted by Syavko1
                                        Re: lenovo thinkpad l14 gen 1
                                        On this bios, the laptop does not turn on at all, the light flashes 3 times and that's it
                                        same problem ineed solution need bios frimware
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
