Microsoft Surface laptop 4 UEFI password
  • sheikhbaizid
    • Sep 2023
    • 17
    • bangladesh
    #201
    Originally posted by ERRA
    HERE, TRY AND REPORT BACK THE RESULT
    not working .windows not open
    • Plato888
      • Dec 2015
      • 16
      Originally posted by koshin
      Try this
      This seems to work better. I'm still being asked for a system password for uefi though?
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1356
        • France
        #203
        Have you tried mine?
        https://www.badcaps.net/forum/troubl...85#post3738385
        • Plato888
          • Dec 2015
          • 16
          I need to reinstall windows via usb which I still can't do. Shall I clone another drive instead perhaps? I've got another Surface Laptop 4.
          MANY THANKS ALSO... BITLOCKER HAS GONE!!
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1356
            • France
            #205
            Bitlocker is not a problem.
            Just erase the disk with the Windows installation.
            • Plato888
              • Dec 2015
              • 16
              Originally posted by Maxpower3
              Damn, no, I missed that one. Cheers for posting it... I'd rather not do any more soldering, I had to replace a resistor on my last effort.
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1356
                • France
                #207
                Koshin cleared the password without disabling the variable.
                Shiyab disabled the variable.
                No one gave you back access to the USBs.
                • Plato888
                  • Dec 2015
                  • 16
                  I'll give yours a go. Hopefully I can do it carefully enough. I'll report back when it's done. 🤞🤞🤞
                  • Plato888
                    • Dec 2015
                    • 16
                    I take it it's the BIN_Patched file?
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1356
                      • France
                      #210
                      yes, the patched one is mine? The other one is your original file?yes patched is mine ? other is your original file
                      • Plato888
                        • Dec 2015
                        • 16
                        Your is working fully (access to UEFI boot etc) 👍 I'm just having problems with the hdd now.
                        • Plato888
                          • Dec 2015
                          • 16
                          The Laptop cannot access it's own ssd to install the OS onto so I will have to investigate further. I'm guessing that this was the original fault before it was disposed of. Thanks for all the help, I'd have no idea how to bypass bitlocker ect. without your assistance.
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1356
                            • France
                            #213
                            try with a recovery surface image with your serial number
                            https://support.microsoft.com/fr-fr/...recovery-image
                            • Plato888
                              • Dec 2015
                              • 16
                              I've done that, I can get to the install windows screen but because the laptop doesn't recognise any hdd installed I can't get any further. I'm guessing it's the motherboard because I tried it with a working Surface Laptop 4 hdd too. I didn't/couldn't check whether it could see a hdd before I asked for help with the bitlocker/uefi locks. It's not an urgent problem, the laptop is for personal use, I don't have a customer waiting.
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1356
                                • France
                                #215
                                if the bitlocker screen . harddrive works
Name:	Sans titre.png
                                • Plato888
                                  • Dec 2015
                                  • 16
                                  The hard drive works, I tested it separately as an external hard drive. Now, the laptop just doesn't see a hdd.
                                  So, if I was getting to the Bitlocker screen before flashing the bios eeprom then you think the laptop was definitely communicating with the hard drive? And, if so, now that it's not working I must have created the problem with my soldering...
                                  I was a bit weary of swapping the chip in and out so much.
                                  • pogradecari
                                    • Oct 2025
                                    • Albania
                                    #217
                                    Plato888 i have the same problem. Did you solve the problem please?
                                    Thank you!
                                    • sabbir
                                      • Mar 2019
                                      • 9
                                      • Bangladesh
                                      #218
                                      Surface model - 1951
                                      S/N 063452123557
                                      could you please unlock this file
                                      Thanks!
                                      • retrooo
                                        • Mar 2017
                                        • 93
                                        • mexico
                                        #219
                                        hi friends can someone help me to unlock this dump
                                        surface 1950 computrace and admin password
                                        serial number:022420413157
                                        thanks in advance
                                        • siwykk
                                          • May 2020
                                          • 55
                                          • N/A
                                          #220
                                          Hello friends,
                                          Surface laptop 4 1979
                                          s/n: 044723124668
                                          Please unlock
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                            Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 05:50 AM
