Lenovo V310 bios edit | I need help
  • dogu06
    • May 2019
    • 33
    • Türkiye
    Hi, my bios file is working well but i can't remove the bios password. I would like to get help.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Lenovo V310 bios edit | I need help
    Try
    • dogu06
      • May 2019
      • 33
      • Türkiye
      Originally posted by hoaca388
      Try
      Because of this file having its "CSE ME" version being different the touchpad isn't working. I need help about removing the password from the bios file i have sent here.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        With the file I posted, will the password be deleted or is it still there?
        • dogu06
          • May 2019
          • 33
          • Türkiye
          Thanks! The bios is working without any problems and the bios password is unlocked. I'm wishing you the best. Stay safe!
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • c.daniel
            Lenovo V310-15IKB weird bios problem...
            by c.daniel
            Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
            sn LR09493E
            MB DAOLV6MB6F0 REV. F
            The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
            Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
            Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
            08-22-2025, 05:39 AM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
          • survivalbloke
            Unable to extract bios file from Lenovo bios exectuable
            by survivalbloke
            I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
            Code:
            "innoextract 7wcn38ww.exe"
            it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
            The trouble I'm having is that I'm not getting the newly...
            06-12-2024, 07:55 AM
          • userbtcku
            I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B
            by userbtcku
            I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B.
            Can anyone help me find the BIOS file for this laptop?
            This laptop is having trouble booting from a flash drive or SSD.
            I've updated the BIOS with a file downloaded from lenovo.com, but it still doesn't work.
            So I'm thinking of flashing it another way.
            11-19-2025, 02:18 AM
