Lenovo G700 whitelist help
  • bobbi2005
    • Feb 2016
    • 6
    • Ukraine
    I have a Lenovo G700.
    My question now:
    Is it possible to remove that whitelist to put a different wi-fi?
    Dump
    Help plizzz
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: Lenovo G700 whitelist help
    just program this 4mb file to your chip, and let me know if its worked fine.
    all donations are welcome,
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • techcraze
      Lenovo 15ARH05 LCD whitelist removal request (Yes. display whitelists....)
      by techcraze
      Long story short. i am building a fully custom car radio. and want to use a extremely bright LCD.
      sadly the DGPU seems to be nonfunctional after i fixed the bios (fried voltage controller). so the Original HDMI port does not work.
      you can use a EDP TO HDMI adapter to add a HDMI port as replacement to the onboard EDP LCD connector,
      HOWEVER it turns out. lenovo enforces a LCD whitelist.
      this means you cannot upgrade the LCD despite matching EDP specs and voltages.
      If i connect a new screen directly to the system. only static shows....
      05-08-2025, 07:50 PM
    • xsd611
      Lenovo X270 Bios - remove Whitelist
      by xsd611
      ​Hello, this is a BIOS file for the Lenovo X270 laptop, read out through a CH341 programmer. I located error 1802 in the PE32 module. This is a detection for the network card's whitelist. How can I bypass or remove the whitelist check? My skills are limited, and I have tried many times but ended up with a black screen. How can I normally bypass this whitelist check? Please help me edit this BIOS file, thank you. It would be great if you could provide illustrations to guide me. Thank you very much!...
      07-13-2025, 09:13 PM
    • LncAhG
      Help disabling BIOS WWAN whitelist on a Lenovo X380 Yoga 20LJS0MP00
      by LncAhG
      My Lenovo X380 Yoga:
      Model: 20LJS0MP00
      SN: MP1ME1R9
      BIOS: 1.41
      BOard: LA-F421P
      does not accept my WWAN cards Sierra 7305 or 7455. I get the dreadful "1802 unauthorised card..." message.
      I have spent hours searching for a patch and stumbled across
      https://github.com/digmorepaka/think...rmware-patches
      I have tried the xx70_xx80_patches_v7.txt file (using UEFIpatch) and some patches could be applied but not
      those of the whitelist section.
      I even extracted the LenovoWmaPolicyDxe_LenovoWmaPolicyDxe...
      09-25-2025, 09:42 AM
