NP730QCJ bios file please
  • interpc
    • Feb 2015
    • 74
    • Mexico
    i need bios dump for
    NP730QCJ
    galaxy book flex
    my dump
    • 22084
    Re: NP730QCJ bios file please
    NP730QCJ
    galaxy book flex
    my dump
    try
    UEFI\RES_{53fccfcc-4ecb-4653-a6b1-2dcbf768c459}
    • eric2022
      Ericscott
      • Jan 2022
      • 47
      • Uganda
      SUMSUNG
      MODEL: NP730QCJ
      SNL:1DPJ91AN600671A
      HELP AND CLEAN STOPS ON SUMSUNG​
      • eric2022
        Ericscott
        • Jan 2022
        • 47
        • Uganda
        Galaxy Book Flex Alpha
        (NP730QCJ)
        pliz help me
        • minhdigital
          • Nov 2022
          • 765
          • Vietnam
          Originally posted by eric2022
          SUMSUNG
          MODEL: NP730QCJ
          SNL:1DPJ91AN600671A
          Send to you, try
            • 22084
            Originally posted by minhdigital
            Send to you, try
            DMI search 42 53 41 5F
            • minhdigital
              • Nov 2022
              • 765
              • Vietnam
              Thanks you
              • David D'oleo
                • Nov 2025
                • República Dominicana
                Hi guys, i need the bios file for prepare a crisis bios usb.
                BRAND: SAMSUNG
                MODEL: NP730QCJ-K01US (Galaxy Book Flex Alpha)
                SN: 3ZF79FGNB01885Z
                Who can helps me?
                • shiyab
                  • Sep 2023
                  • 1646
                  • india
                  BRAND: SAMSUNG
                  SN: 3ZF79FGNB01885Z
                  Who can helps me?
                  POST BAckup bios and snid
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • bondminer009
                    Need Bios for Latitude 7650 (No Original / dump bios file)
                    by bondminer009
                    Good Evening,
                    Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                    Thank You
                    Salam,
                    Three
                    11-12-2024, 07:48 AM
                  • joshAU
                    BIOS file for N550JK (original dump attached)
                    by joshAU
                    Hi all.
                    I'm looking for a BIOS file for an Asus N550JK.
                    I have a Asus R552J, which I believe is identical to the Asus N550JK.
                    I downloaded the latest BIOS (210) for the R552.
                    It is named N550JKAS.210.
                    The BIOS file is however only 6mb in size.
                    I've read the chip with a CH341A programmer and verified the file.
                    That file is actually 8mb in size.
                    I'm wanting to remove the BIOS password from this unit.
                    It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                    08-09-2022, 08:06 PM
                  • adelage
                    Merge ECS Z77-H2 bios cap file with original dump
                    by adelage
                    I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                    03-11-2025, 03:07 AM
                  • m1ch43lzm
                    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                    by m1ch43lzm
                    Hi everyone
                    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                    There's also an extra OTP Secu.R...
                    09-06-2025, 05:47 PM
