Hp model 15-dw1233nia bios bin
  • arber1232
    • Dec 2019
    • 386
    • Albania
    hi everyone i have Hp model 15-dw1233nia turn on but black screen
    i need bios for this FW50 LA-H325P REV 1.0
    I not have old bios becouse ic not dected .
    Serial number :CNDI2803BY
    Part number :2T1Z1EA
    XMC XM25QH64AHIG this is ic any equvalent for this i can use winbond 25q64 ?
    • 22279
    Re: Hp model 15-dw1233nia bios bin
    What model is your programmer,and software version
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      HP 15-dw1000 Laptop PC (8SU35AV)
        • 22279
        There are quite a few programmers that don`t have support for the XM25QH64AHIG .If the OP can tell us what programmer he has then we can suggest software to use or a different chip ID, if the chip can be read then it will be easy to copy the DMI
        • arber1232
          • Dec 2019
          • 386
          • Albania
          MiniPro v6.85
          TL866CS Miniprogramer
          • Bonzas
            • 474
            • Indonesia
            MiniPro v6.85
            Try with software V12.11, or you can use CH341 with Colibri programmer
            • arber1232
              • Dec 2019
              • 386
              • Albania
              what programmer do you suggest me to buy
              i see this XGecu_ T56 Programmer is good ?
              • bahimovicbnn1
                • Nov 2022
                • morocco²
                hp 15-dw1000nk bios file bin
                • qayyum786
                  • Aug 2018
                  • 1959
                  • INDIA
                  make a backup
                  match your $BID from POST #3 and flash
                    • 22279
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • TyMercer
                      Can I flash a working BIOS from one computer to another of the same make, model, etc?
                      by TyMercer
                      Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                      11-13-2025, 09:39 PM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
                    • ldogg
                      need a bios for model tuf516pr
                      by ldogg
                      im looking for a bios for
                      serial: m9nrkd02310938g
                      model:tuf516pr-bs71-cb
                      cn: sw3z
                      mfd: 2021-09
                      its bios locked. my 14 year old son did it and dont know how. tried to reprogram but cant find a bios. attached what i think is the original if i picked the right chip on the mobo...
                      11-04-2025, 04:45 PM
                    • Loki_Fido
                      BIOS for Microsoft Surface Laptop 7 - Model 2036
                      by Loki_Fido
                      Hi ya folks,
                      Attached is the BIOS from a Microsoft Surface Laptop 7 - Model 2036
                      As of right now i am unable to confirm whether this BIOS dump works or not.
                      But i will update soon. Hopefully in a day or two.
                      Given that no one else uploaded any BIOS backup for this laptop, I thought i might as well start a new thread and upload what i have.
                      Microsoft Surface Laptop 7th edition
                      Model 2036
                      SN 0F3CPFB24153HH
                      Remember, If you tried to read this chip with CH341A, this device will not identify this chip for you.
                      Both ASProgrammer...
                      09-11-2025, 04:00 AM
