Need BIOS EPK50 LA-G07BP
  • computeka
    • Apr 2021
    • 31
    • colombia
    Need BIOS for hp 15-da0015la
    EPK50 LA-G07BP Rev: 2.0
    • 21523
    Re: Need BIOS EPK50 LA-G07BP
    Do you have a backup ?
    • snakeccc
      • 5
      • Bosnia and Herzegovina
      I'am currently experiencing some problems with one HP laptop.
      Can't verify and find what BIOS to flash.
      Laptop: HP 15-da0035nm
      Motherboard: EPK50 LA-G07BP Rev:1.0 2018-03-08
      If someone can help, would higly apriciate.
      Original bios dump in attachment.
    • snakeccc
      • 5
      SN: CND839896S
      • hoaca388
        Badcaps
        • Jan 2022
        • 12182
        SN: CND839896S
        HP Notebook - 15-da0035nm
        Can't find BID on your root file but there are three 8MB bios files, you have to try all three.
        • snakeccc
          • 5
          BID is problem for me from start. I have tried first 3 no luck, just power on and stops.
          With original one I had spinning of ventilators, but now same even if I flash old bios
            • 21523
            The 15-da0035nm has an i5-8250U Kaby Lake R refresh CPU .
            084A8 has Braswell/Cherry Trail TXE firmware
            084AA has Gemini Lake TXE firmware
            086B3 has Comet Lake CSME firmware
            086C1 has Ice Lake CSME firmware
            08532 has Comet Lake CSME firmware
            Only 084A6 has ME 11 KBP firmware
              • 21523
              Your original bios backup is corrupt and can`t be repaired.Flash the 084A6 virgin bios.
ID:	3259709 Click image for larger version
              • snakeccc
                • 5
                Click image for larger version  Name:	Capture.jpg Views:	37 Size:	82.4 KB ID:	3259709 Click image for larger version  Name:	Capture1.jpg Views:	7 Size:	32.1 KB ID:	3259710
                Flashed virgin bios , laptop ventilator spinning all the time. On caps lock have error 5.3.
                  SMDFlea commented
                  Editing a comment
                  Check the ram slot for loose pins especially on each end
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
                by Vesko356
                08-11-2023, 03:27 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
