Password - Lenovo İdeapad 3 15ITL6 - hs460 hs560 hs760 nm-d471
Yes. If you post your bios backup someone will help.Comment
Can someone help me clean the bios?
Attached Filesif you find these attachements useful please consider making a small donation to the site
ideapad 3-14ITL6 Laptop - Type 82H7
https://www.badcaps.net/donateComment
I have a Lenovo laptop, model IdeaPad 3-15ITL6 82H8, S/N: PF4CA2MD and BIOS MODEL: GGCN51WW. It turns out that when I try to access the SETUP it asks me to enter the SYSTEM PASSWORD. Is there any solution for this problem? I am attaching a backup of the BIOS in case you can help me.Attached Filesif you find these attachements useful please consider making a small donation to the site
Where's origin bios file ?I have a Lenovo laptop, model IdeaPad 3-15ITL6 82H8, S/N: PF4CA2MD and BIOS MODEL: GGCN51WW. It turns out that when I try to access the SETUP it asks me to enter the SYSTEM PASSWORD. Is there any solution for this problem? I am attaching a backup of the BIOS in case you can help me.↵
this file no a bakup his new filI have a Lenovo laptop, model IdeaPad 3-15ITL6 82H8, S/N: PF4CA2MD and BIOS MODEL: GGCN51WW. It turns out that when I try to access the SETUP it asks me to enter the SYSTEM PASSWORD. Is there any solution for this problem? I am attaching a backup of the BIOS in case you can help me.
Model : Ideapad 15ITL6
S/N : PF2RHNTDAttached Filesif you find these attachements useful please consider making a small donation to the site
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
try post #14..
https://www.badcaps.net/forum/troubl...l6#post3299726Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Please help, my laptop has no image after turning on and the power light
keeps blinking. I will upload the original file with the motherboard specifications.
ideapad 3 15ITL6
HS460 HS560NM-D472
REV:2.0
VENDOR:GBM
2020-12-10Attached Filesif you find these attachements useful please consider making a small donation to the site
you have everything you need at post #14..
https://www.badcaps.net/forum/troubl...eapad-3-15itl6Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hi guys, I really need help please, I'm new to this , I read the 2 x bios chips/ files with CH341 programmer from Ideapd 3 15ITL6 which had a password lock on it, I wanted to get rid of the password, I saved these bios files and wrote/ptogrammed the "virgin" bios files I found on this thread to these bios chips not knowing about DMI etc. Unfortuantely my PC's hard drive crashed and I lost the original BIOS bins.
Can the Bios be rebuilt with just the serial numbers of the laptop?Comment
no... it works without the DMI information, just with the virgin bios... you will receive a message at the beginning, after which it enters windows...Hi guys, I really need help please, I'm new to this , I read the 2 x bios chips/ files with CH341 programmer from Ideapd 3 15ITL6 which had a password lock on it, I wanted to get rid of the password, I saved these bios files and wrote/ptogrammed the "virgin" bios files I found on this thread to these bios chips not knowing about DMI etc. Unfortuantely my PC's hard drive crashed and I lost the original BIOS bins.
Can the Bios be rebuilt with just the serial numbers of the laptop?Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Could someone help me by editing my bios by disabling the internal memory?
by elharouriamine won't turn on. if you press the power it flashes 12 times on the power button
so i need a helpe please
motherboard hs460 hs560 hs760 nm-d471 Rev 2.0 -
I have laptop Lenovo IdeaPad 3 15ITL6 with Intel Core i3-1115G4. When I press the start button, LED light on the start button starts blinking 12 times, then stops and after some time starts blinking 12 times again. When it stops, all voltages are down.
The motherboard is HS460 HS560 HS760 NM-D471 Rev: 2.0
S/N: PF3Q0WTF
The motherboard is not mine, also there were corrosion on the board which I cleaned.
Methods of fixing like fully turning off the motherboard or starting only with adapter doesn't work. All testing were did only with adapter on.
...06-07-2025, 02:40 AM -
by lrserviciosLenovo Ideapad 3 15ITL6 S/N: PF2RXCVG HS460 HS560 HS760- NM-D471 REV: 2.0
I suspect bios faliure because laptops start and power led keeps blinking please can you repair this BIOS for me please ??...-
Channel: BIOS Requests ONLY!
by samstownHello
I've got a Lenovo that stopped working. No sign of life at all. I was hoping it would be an easy fix but I am not sure it's mosfet, I think resistance should be low but it's OL.
Thermal camera show MOSFET heartbeat.... It's Sinopower SM4377.
Sam... - Loading...
