Acer Nitro 5 / AN515-44 - need BIOS file
  • shog
    • Jan 2022
    • 37
    • Poland
    Laptop: Acer Nitro 5 / AN515-44-R9GT
    Hello, somebody left this laptop with soldered bios chip, I'm pretty sure the dump inside this chip is not correct (laptop is dead), and I don't have original dump.
    I am asking for bios file for this model
    The file I attached is what was inside bios after somebody else desoldered it
    • 20884
    Re: Acer Nitro 5 / AN515-44 - need BIOS file
    post the laptop serial number, and the motherboard part number
    • shog
      • Jan 2022
      • 37
      • Poland
      S/N: NHQ9GEP00C0200D0FE3400
      Motherboard: FH51S LA-K181P Rev: 1.0
      • shog
        • Jan 2022
        • 37
        • Poland
        Also, do you know if I need to program EC chip separately on this model?
        • DanielDacko
          • Mar 2015
          • 325
          • Macedonia
          Here you go, both main and EC extracted from official latest update, according to your serial number.
          I don't provide help for people using CH341A and a clip.
          • shog
            • Jan 2022
            • 37
            • Poland
            Thank you, I tried it, motherboard acts the same, but now I know that the problem is probably not in bios
            • mferna14
              • Jun 2018
              • 1020
              Hi all, I am woking on an ACER Nitro 5 AN515-44-R99Q, problem is that after an update the screen went blank & NO DISPLAY at all. I removed the main & CMOS battery still no luck, no reset switch for this model. The fans are running in full speed & no display at all. But when I remove the power cord for the DC-in, I hear the chime sound that it running on battery. I checked the ram, BIOS, CPU, VCORE Voltages, all are fine according to the schematics. I am assuming its just the BIOS problem. If some can re-build the Original BIN files I have attached. The serial number for this ACER model is NHQ9GAA00111907CCC3400 SNID:11903194834 (MFG Date: 2021/05/12)... Thanks in advance
              • peste
                • Dec 2016
                • 12792
                • ROMANIA
                have you tried post #5...
                • mferna14
                  • Jun 2018
                  • 1020
                  Yes, tried the BIN files in post # 5, does not work, (same blank screen & fan runs fast).. Do you think that something else might have gone wrong with the motherboard??
                    • 20884
                    Try another bios chip,your backup is very corrupt.You didn`t use a clip to make the backup did you
                    • mferna14
                      • Jun 2018
                      • 1020
                      Actually the programmer could not pick up the correct BIOS Name & it actually number. So I picked up a generic number. For this model, ACER used a XMC BIOS 25QU128BH1Q. So I used a closet to this model. I think this is a 1.8V BIOS., pls. correct me if I am wrong & which one should I choose, thanks?
                      • DanielDacko
                        • Mar 2015
                        • 325
                        • Macedonia
                        Original chip is working on 3.3V and you have selected one that works on 1.8V. Google the chips before selecting.
                        • mferna14
                          • Jun 2018
                          • 1020
                          In my case ACER used this chip XM25QU128B which works from 1.65V~1.95V. I even checked the working voltage of this BIOS chip on the motherboard when I turned the MB on, VCC on pin 8 is full 1.82V, schematic even shows 1.8V. The PDF information on this BIOS is "128MB 1.8V SERIAL FLASH MEMORY WITH 133MHZ MULTI I/O SPI & QUAD I/O QPI DTR INTERFACE".... But the problem was that I could not find this series XM25QU128B in the listing. Please inform me what to select to get the Original BIOS read correctly. Thanks
                          • mferna14
                            • Jun 2018
                            • 1020
                            SMDFlea., Now, hopefully I have uploaded the BIOS & have read it well with the right Chip number. Can you please check it & modify or re-build the BIOS Bin file. This BIOS chip XM25QU128B is 1.8V BIOS & it read well with 1.8V selected as it operating voltage. The serial number for this ACER model is NHQ9GAA00111907CCC3400 SNID:11903194834 (MFG Date: 2021/05/12). Appreciate your help.
