A1502 EMC2835 can´t insert another Serial
+ More Options
Posts
  • focus2k
    • Jan 2020
    • 28
    Hello all,
    i just tried to insert the Serial C02RK106FVH6 in the attached Bios.
    I tried to insert and Clean the Region, but it does not work.
    Could anyone insert the Serial into this BIOS? THX a lot.
  • Mazorca
    • Jan 2017
    • 463
    Re: A1502 EMC2835 can´t insert another Serial
    Try it now
    • focus2k
      • Jan 2020
      • 28
      Working �� thx a lot
      • Dannyx
        UART (serial ?) splitter ?
        by Dannyx
        Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
        The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
        The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
        08-18-2023, 03:21 PM
      • baletak
        Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
        by baletak
        had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
        I have updated laptop model number.
        1) I did not find the way to update laptop serial number - I have this one.
        2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
        Hope to find someone to help me with this as I am hitting dead end at the moment.
        Many thanks
        Miro
        05-23-2025, 01:21 AM
      • Friend33
        Updating Serial Number on EliteBook x360 1030 G3
        by Friend33
        I have an EliteBook x360 1030 G3 and after a motherboard replacement, I want to change the serial number and the FeatureByte. None of the known methods work. MPM is locked and cannot be unlocked via EFI.
        Therefore, I read out the two chips and adjusted the serial number, FeatureByte, and Born Date using a hex editor. Now the system won't start anymore. I think I did something wrong with the FeatureByte, as there was a message indicating that the file size was changing.
        My serial number is: 5CD849BL7Q
        FeatureByte:
        3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6dUdpdq
        06-20-2024, 03:55 PM
      • Friend33
        Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
        by Friend33
        I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
        06-16-2024, 03:13 PM
      • AWFRONT
        [Help Please!] Lenovo ThinkBook Plus Gen4 Twist-Help Needed with Restoring Serial Number and Product ID
        by AWFRONT
        I have recently purchased a Lenovo ThinkBook Plus Gen4 Twist with Dual Screen. Here are the links for the product information:
        ThinkBook Plus Gen 4 (13″ Intel) | 13.3″ & 12″ Dual-Screen 2-in-1 Business Laptop | Lenovo UK
        However, somehow the serial number and the product name is no longer showing under the BIOS, Windows 11 or Lenovo Vantage.
        Strangely the laptop's under cover does not show any information about the Make, Model, Type or Serial Number (No sign of tampering but no labels etc...). I am not sure what to do.
        I do not have access to the original box...
        06-21-2025, 11:09 AM
