820-3209a bios need
  • biber
    • Feb 2015
    • 104
    • macedonia
    820-3209a bios need
    hi i need bios for this mb, chip is dead so i dont have dump.
    cpu: i5
    8g ram
    bios chip:
    MX25L6406E
  • DanielDacko
    • Mar 2015
    • 325
    • Macedonia
    Re: 820-3209a bios need
    Serial number? Pozdrav
    I don't provide help for people using CH341A and a clip.
    • biber
      • Feb 2015
      • 104
      • macedonia
      dont have serial number, i have only mb not chassis. pozdrav nice to see people from macedonia here :P
      • DanielDacko
        • Mar 2015
        • 325
        • Macedonia
        Something like this on the mainboard?
        • biber
          • Feb 2015
          • 104
          • macedonia
          Oh i thought serial number of a laptop. Have this, i will write tomorrow.tnx
          • biber
            • Feb 2015
            • 104
            • macedonia
            C02235007rf25ta2
            mlb 1.8ghz hy 8gb
            • DanielDacko
              • Mar 2015
              • 325
              • Macedonia
              Try this...
              • biber
                • Feb 2015
                • 104
                • macedonia
                bios works but cant install nothing above mac os x lion. this board should support catalina.
                • biber
                  • Feb 2015
                  • 104
                  • macedonia
                  firmware update fixed this issue. job done. tnx
                  • OmanCloud
                    • Aug 2023
                    • 13
                    • Oman
                    Try this...
                    nice work brother 🤠🤠🤠🤠
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • thxd43
                      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                      by thxd43
                      Hello, first of all, excuse me, I am using the translator, English is not my native language.
                      I have a Lenovo ideapad 330S - 14IKB laptop.
                      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                      02-23-2023, 08:37 PM
                    • hotcrossedbuns999
                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                      by hotcrossedbuns999
                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                      3. I could only locate two chips that look like bios chips. Could someone verify this
                      01-03-2025, 12:32 PM
                    • inck243
                      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                      by inck243
                      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                      The BIOS...
                      07-25-2024, 09:17 AM
