Hp 15s-fq0000ni bios request
  • mnciks11
    • Aug 2019
    • 347
    • south Africa
    Hello guys
    i need the bios bin for the Hp 15s-fq0000ni
    S/N 5CD0202ZT5
    The laptop turns on, screen flashes fast 2 times with whites, and then the caps lock flashes 5 time and 3 fast flashes , when i checked online they said its the bios.
    I cant find the bin file for this machine please help clean the ME REGION
    BELOW IS MY BACKUP FILE
    • 22293
    Re: Hp 15s-fq0000ni bios request
    Originally posted by mnciks11
    Hello guys
    S/N 5CD0202ZT5
    How to clean ME/TXE region
    https://www.badcaps.net/forum/showpo...41&postcount=3
    If you can`t do it and you want an easier way just go to HP support,enter your serial number,download the bios update. Run the exe and select save to location. Open your bios backup with a hex editor,search for the word BID . Open the matching BID bios you saved with your hex editor. Copy the DMI information and win key from your backup to the new bios.
    DMI 747000 - 7480FF
    KEY 76D000 - 76D03F
    • istvanszasz99
      Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
      by istvanszasz99
      Product ID: RZ09-0421
      Motherboard: CH580
      Bios File Size: 32,768 KB
      Dear Forum Readers!
      !!! MY RAZER BLADE...
      11-24-2025, 05:52 PM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
