Dell Latitude 3420 BIOS - Manufacturing Mode Required
  • CapThatBrass
    • Oct 2021
    • 46
    I'm having some issues with a Dell Latitude 3420 laptop I'm working with. The chip itself is an XMC25RH256CXIQ but I've not been able to find the exact settings for this chip using NeoProgrammer.
    Instead, I've made a dump of the image using the following three chip settings within the software:
    - XC25QW256C
    - W25Q256BV
    - MX25L25635E
    All three images have been uploaded. Oddly enough all three images aren't identical, but I'm guessing that the XMC XC25QW256C version might be the closest match.
    If someone can help with creating a Manufacturing Mode (to enter the ST number) version of this BIN file, it would be greatly appreciated.
    Cheers
  • CapThatBrass
    • Oct 2021
    • 46
    Re: Dell Latitude 3420 BIOS - Manufacturing Mode Required
    Sorry I forgot to mention that the Service Tag/serial on the machine in question is FHGVQG3. If Manufacturing Mode isn't possible, having the BIOS configured with this serial would be great.
    Thanks for any help
    • gzhding
      • Aug 2022
      • 9
      I have the same need to
      • dandaman2234
        • Jul 2015
        • 6
        • United Kingdom
        Dell Latitude 3420 - EC Region 'Reset' Needed (MPM Unlock)
        Can someone please help with replacing/'resetting' the EC region of the attached BIOS image?
        Laptop is a Dell Latitude 3420.
        Thanks guys
        • hoaca388
          Badcaps
          • Jan 2022
          • 11807
          Re: Dell Latitude 3420 - EC Region 'Reset' Needed (MPM Unlock)
          Thanks guys
          Your file not good, use a programmer for dump content of bios chip.
          • dandaman2234
            • Jul 2015
            • 6
            • United Kingdom
            Thanks for looking at this hoaca388.
            I took the bios dump (uploaded yesterday) with my rt809f programmer.
            I since attempted several other dumps of the chip but each time the results are different (in total I have 8 dumps now). The latest version I've attached.
            I then released I was dumping the data using the GD25Q256C@SOP16 settings (within the iFix program). I've since switched to the appropriate WSON8 settings (the dump for this can be seen below).
            I also found on the rear of the motherboard is a smaller GigaDevice 25Q80EWIG chip, which I dumped and have uploaded the image. After several attempts of this dump, each result is exactly the same.
            I've taken a photo of the location on the motherboard which I believe to be the main BIOS chip but it may have another use such as a Thunderbolt controller (this may explain the changing nature of the data within).
            Any help would be great.
            Cheers
            • hoaca388
              Badcaps
              • Jan 2022
              • 11807
              Cheers
              All results are corrupt, the GigaDevice 25R256EYIG chip contains 32MB of data ( this is the bios chip ), when compressing to the rar file should be around 10MB to 12MB, try updating the latest software for your RT809F.
              The GigaDevice 25Q80EWIG chip is not a bios chip, it only contains 1MB of data.
              • dandaman2234
                • Jul 2015
                • 6
                • United Kingdom
                Thanks hoaca388.
                Is the attached BIOS dump any better? The compressed file size is definitely larger than before.
                Cheers
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11807
                  Thanks hoaca388.
                  Cheers
                  Not yet, try one more time, read chip at least 3 times, this file's description is missing.
                  • dandaman2234
                    • Jul 2015
                    • 6
                    • United Kingdom
                    Thanks hoaca388.
                    I took some time to do some testing (thought my rt809f had broken, but it hadn't thankfully) - I was able to read/write BIOS images on another working laptop I have.
                    I managed to get another 3420 board, this time with an MXIC MX77L25650FZ4I42A BIOS chip installed (full model number is longer with 'L222862' included). This chip isn't listed within the iFix software unfortunately but after googling the chip specs, it seems to match the specs of the 'W25Q256FV@WSON8 8X6' option within the iFix Application. So I took the risk and it worked out - the latest BIOS dump I have it attached here. I've checked the image this time and it looks to be working within ME Analyzer.
                    If you can look at this one for more that'd be sound.
                    Cheers
                    • dandaman2234
                      • Jul 2015
                      • 6
                      • United Kingdom
                      If you can take a look at the latest BIOS dump uploaded hoaca388, that would be great.
                      Cheers
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11807
                        Cheers
                        Latitude 3420
                        • dhan
                          • Jun 2018
                          • 134
                          • hp
                          Please help to remove computrace.
                          thanks in advance
                          • hardware1
                            • Sep 2021
                            • 2937
                            • N/A
                            thanks in advance
                            Write your Device Service Tag.
                            all donations are welcome,
                            • dhan
                              • Jun 2018
                              • 134
                              • hp
                              write your device service tag.
                              2w6shl3
                              • hardware1
                                • Sep 2021
                                • 2937
                                • N/A
                                2w6shl3
                                Try.
                                • Jdpaz
                                  • Aug 2022
                                  • 12
                                  • Philippines
                                  Please help with bios password Serial Tag 6T7KBS3
                                  • peste
                                    • Dec 2016
                                    • 12878
                                    • ROMANIA
                                    try..
                                    • Jdpaz
                                      • Aug 2022
                                      • 12
                                      • Philippines
                                      Please help with bios password Serial Tag HRRJBS3
                                      • LBTT1121
                                        • Nov 2024
                                        • 564
                                        • Việt Nam
                                        try
                                          DELL Latitude 3420 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3420 boardview and 3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 3420...
                                          09-07-2024, 01:30 AM
