HP 650 G1 (Your machine is not in committed state)
  • suny99
    • Mar 2016
    • 6
    • croatia
    I have HP 650 G1 which was bricked.
    Bricked file is attached: backup.zip
    Using CH431A I was successful in flashing .bin that I have found here on forum
    (file attached PROBOOK 650G1.zip)
    But the problem was that there was error message:
    After that white screen with listed items:
    Product name
    Product serial number
    Product SKU
    Product family
    CT number
    Using MPM tool I was able to add all of the listed items (Can't say I'm sure that I did it correctly)
    And after that there's no more white screen with missing items.
    But there's still message:
    I have googled it and found some solutions but to be honest all that seemed out of my reach.
    Can anyone tell me what should I do to remove that message?
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: HP 650 G1 (Your machine is not in committed state)
    Product name
    Product SKU
    Product family
    CT number
    Become a Badcaps supporter
    Thanks to all supporters.​
    • suny99
      • Mar 2016
      • 6
      • croatia
      Originally posted by Vesko356
      Thank you for your help. But now I'm back again at the white screen with listed missing items:
      Product name
      Product SKU
      Product family
      CT number
      Before white screen I have a message manufacture mode set on 2 out of 10
      EDIT:
      Ignore written above. Using MPM tool for HP, like earlier, I manually entered all asked data
      and now there's no more error's and laptop is working.
      @Vesko356
      Thank you so much for your help.
      If you have some time pls explain what have you done to remove
      "Your machine is not in committed state"
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        That's right, you got it right. One of the ways when the manufacturing mode is active (so that the data can be entered) is to enter it directly one after the other in the BIOS as shown in this video for example, and the other is to use the MPM tool (and there is another third way too ). By the way, the dump had a BIOS password that I removed , if you installed it and you want it to be so, you can do it again. Regarding the "Machine is not in committed state" problem is too long to explain, in general the typical HP nonsense aimed at punishing the end user with unnecessary headaches (or unnecessary spend of money and time to visit the "authorized" service station to fix the problem).
        • suny99
          • Mar 2016
          • 6
          • croatia
          It's fine that you removed password I didn't need it. I understand and I'm glad that there is a way to fix "Machine is not in committed state" without going to "authorized" service station otherwise it would be such a pain in the a**. Thank you once again, you basically helped me give life back to this laptop. I don't even understand how previous user bricked it. I mean CMOS battery was at 2.5 V maybe that's the cause, who knows.
          • sc84647
            HP Elitebook 840 G3 - "Machine is not in committed state"
            by sc84647
            Hi
            I have an EliteBook 840 G3 that boots with "Machine is not in committed state!", the system info is correct when displayed in the BIOS screen:
            Serial Number : 5CG6481F5D
            Product Number : L3C65AV
            Description : HP EliteBook 840 G3
            I've tried using the BiosConfigUtility.exe from HP BCU (SP143621) which says MPM is in Lock state, and if I try changing that using that tool I get:
            <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access Denied" returnCode="6">
            <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
            02-11-2024, 08:27 AM
          • darksideofthemoon
            Hp Elitebook 820 G1 "warning!! machine is not in committed state"
            by darksideofthemoon
            I bought a new motherboard for my HP Elitebook 820 G1 but the warning error appears when I turn it on"
            I realized that since it was a virgin card, some data was missing... I took it from the notebook's plate and inserted it with a tool found online but the error remains. I can't find the BUILD ID (not even on the partsurfer site). Is there a way to recover it? I also have a bios backup from the previous card, could I recover it from there? Thanks and sorry for the bad English
            10-08-2023, 10:02 AM
          • pcproffsen
            Elitebook 850 G1 "machine is not in committed state"
            by pcproffsen
            What are the Brands about?
            Which one is for what PC model?
            I have a Elitebook 850 G1, with the problem "machine is not in committed state" showing at boot.
            But I can login to Bios, and everything looks ok there. And no hardware is changed.
            I also updated to latest Bios version.
            So I just dont understand why this message shows, how can I get rid of it?...
            03-30-2023, 11:43 AM
          • Kamus291
            HP 650 G1 - machine not in committed state
            by Kamus291
            I have an HP 650 G1
            Motherboard was changed but I do not have backup of old BIOS
            I get "machine not in committed state" when laptop starts
            CPU is over heating. I do not know if related.
            Tried BIOS from below link. Laptop do not boot.
            https://www.badcaps.net/forum/showpo...00&postcount=7
            I get "MPM is not unlocked", when using "HP Manufacture Programming MPM Unlock tool down"
            See attached BIOS, CT from new board and serial number of laptop
            Can someone please...
            03-07-2023, 12:37 PM
            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-12-2024, 03:28 PM
