Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
  • peste
    replied
    Re: Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    Originally posted by carloska
    Hi!
    Can somebody help me reading content of SPI ROM chip for my laptop?
    The technician told me, that the bios is good, but in meantime we lost the original content of Super IO chip witch is in the other side of motherBoard.
    He told me, that it would help, if I could get the same version of my laptop from somebody and read the content of that chip, but I found no one in my region.
    The laptop powers on, but does not boot, power button blinks.
    Lenovo IdeaPad L340-17IRH Gaming
    Model Name: 81LL
    SN: PF1TB56 MTM: 81LL00CYGE
    Mfg Date 2020/10/17 Factory ID. JVHFC1
    MO: PE9XB0A17136
    MotherBoard: NM-C361 rev 1.0
    Thanks!
    you have everything you need at post #6...
  • carloska
    replied
    Hi!
    Model Name: 81LL
    MO: PE9XB0A17136
    Thanks!
  • Miim113
    replied
    Originally posted by SMDFlea
    There`s nothing wrong with that bios. If you want to try a newer version try the one at post #27 .If that doesn`t work you could try flashing the EC. Hardware issue or EC ? ,don`t know.
    Can you give me dump for "GD AH2033 25LQ80CTIG UAK261"?
  • Miim113
    replied
    In EC file I don't need to change nothing?
    replied
    Originally posted by Miim113
    Sorry man!
  • Miim113
    replied
    Originally posted by Vesko356
    You must attach files directly to your post instead of linking to external websites!
    Read the rules before posting:
    Sorry man!
  • Vesko356
    replied
    https://*******/file/szgHWLjS#4S7qMF...mTyYovXNwn1v00
    this is the modified bios what I write in chip
  • Miim113
    replied
    Same result... nothing changed
  • Miim113
    replied
    forget the EC, just flash the bios from post #6
    replied
    In ec what need to modify?
  • Miim113
    replied
    You can give me the adresses? Please... I must to edit in 2 files?
  • Miim113
    replied
    Originally posted by peste
    you have at post #6 the interval in which the DMI information is located, use the HxD program and pass the information from your bios, into the bios from post #6 which is virgin.. select the area and (copy - paste)..
  • peste
    replied
    Hi. Don't need to put sn? The laptop was at many services, and don't have nothing... I wolud put new chips...
    regards
  • Miim113
    replied
    if you read the whole thread before posting, you would have solved the problem a long time ago.. you would have known you had to go to post #6... when you make a bios request, they always post the bios even if it is corrupted..
    regards
  • peste
    replied
    Hi!
    Can somebody make me good ec, spi rom and bios file too for this laptop?
    Model Name: 81LL
    SN: PF1TB56 MTM: 81LLOOCYGE
    MO: PE9XB0A17136
    NM-C361 rev 1.0
    Thanks!
  • Miim113
    replied
    Hi!
    Model Name: 81LL
    MO: PE9XB0A17136
    NM-C361 rev 1.0
    Thanks!
  • hardware1
    replied
    Originally posted by fifi88
    Your file is same as my backup.
    FG541/FG741 NM-C361 rev.1.0
    I was able to find the model and serial number on the box.
    IdeaPad L340-17IRH
    SN : PF1BRP56
    You mean my file gives you the same symptoms or behavior?
    According to your Serial Number, the file which I attached should works fine.
  • fifi88
    replied
    Try this file, it's a Virgin BIOS from Lenovo with your DMI.
    At least write your Motherboard Number.
    IdeaPad L340-17IRH
    SN : PF1BRP56
  • hardware1
    replied
    my laptop behaves very similarly. The power button flashes 6 times, current consumption is about 0.30A. Unfortunately, I do not know the exact model or serial number because the sticker has been damaged.
    I have attached the bios I read.
    I would ask for the correct bios and input to the EC.
  • fifi88
    replied
  • jendkkd jeje
    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
    by jendkkd jeje
    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
    10-11-2024, 03:12 PM
  • AHmad_Salal
    Need BIOS Dump/ROM for Lenovo Thinkstation p500
    by AHmad_Salal
    Hello all,
    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
    11-28-2023, 05:28 AM
  • Ahari
    by Ahari
    I...
    Yesterday, 06:12 AM
  • mximiliandz
    help bios lenovo ideapad s145-14iil type 81w6
    by mximiliandz
    Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
    06-20-2025, 06:50 AM
  • hirens
    Lenovo ideapad 3 14IGL05 bios dump needed
    by hirens
    model: 81wh
    sn: pf36ta6h
    board no: nm-c961 gs453/gs553
    hey guys above is my laptop info
    it only blinks the power button kindly help me with a working dump
    old dump attached...
    07-21-2023, 04:48 AM
