Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    replied
    Re: Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    Originally posted by outsider
    I don't undersand.
    sn: Pf1blapu
    Lenovos usually have a Model Type/Machine Type part number as well as a serial.
    The bios youve tried already are ok,your problem is somewhere else.
  • hoaca388
    replied
    Check from the serial number that the bios has been downloaded correctly. Check the hardware again.
  • outsider
    replied
    Originally posted by smdflea
    post the laptop serial number.
    sn: Pf1blapu
  • outsider
    replied
    Originally posted by hoaca388
    EC file
    Still no change
    replied
    Hmmm maybe EC? You have dump?
    Post the laptop serial number.
  • hoaca388
    replied
    EC file
  • outsider
    replied
  • hoaca388
    replied
    Still the same effect. Maybe can You clen my ME Region. I try to clean but i have error "The ME/TXE region is corrupted or missing"
    The bios I posted is almost complete unpacked from the Lenovo homepage with a clean Me region, I just added the DMI info from your old bios to it.
  • outsider
    replied
    L340-17IRH Gaming Laptop
  • hoaca388
    replied
    I don't undersand.
    satishkumar
    I reprograming Your dump but still the same effect. Motherboard consumption about 1.2A power led blinking 15 second and motherboard power off.
    Here is my batch, but I don't know if it is functional or someone has not modified it before.
    Thanks!
  • outsider
    replied
    Originally posted by SMDFlea
    Post the model type.Make a backup first before trying any other bios .
    I don't undersand.
    satishkumar
    Thanks!
    replied
    Hello!
    I need bios for this model
    PCB: FG541/FG741 NM-C361 REV:1.0
    CPU: i5-9300H SRF6X
    GPU: GTX 1650 N18P-G0-MP-A1
    PCH: SR40B
    25Q128JVSQ
    IT8586E FXS
  • satishkumar
    replied
    hello!
    lenovo ideapad l340-17irh
    pcb: Fg541/fg741 nm-c361 rev:1.0
    cpu: I5-9300h srf6x
    gpu: Gtx 1650 n18p-g0-mp-a1
    pch: Sr40b
    25q128jvsq
    it8586e fxs
  • outsider
    replied
    Hello!
    CPU: i5-9300H SRF6X
    PCH: SR40B
    25Q128JVSQ
    IT8586E FXS
  • jimore
    replied
    Re: Lenovo L340 clear bios
    Originally posted by peste
    try..
    thanks tested working forme
    ideapad l340-151rh model-81lk
  • btomce
    replied
    Still no screen..May be i need insert region part from my original dump into update?
  • btomce
    replied
    my number is 81LL0042PB .
    replied
    Originally posted by btomce
    So i think the nvidia gtx 1650 must be in bios dump,
    official update bios for 1050 only ,true ?
    How can check it?
    The vBios for both is in the official bios,and also bios dumps of exactly the same spec.Is the laptop working now ?
    The L340-17IRH 81LL is sold in 2 configurations in your country - https://psref.lenovo.com/Product/_/i...uania&country=
    The 81LL0064LT has the GTX 1650 ,the 81LL00BFLT has the GTX1050
  • btomce
    replied
    How can check it?
    replied
    Bios + DMI + EC ,extracted from lenovo update.
    L340-17IRH Gaming Laptop (ideapad) - Type 81LL
    DMI 632000 - 633FFF (0x0632000 - 0x0633FFF)
    Copy your own DMI to the new bios easily using the attached "L340-17IRH CopyDMI" script.See the README.txt file for instructions.
    Last edited by SMDFlea; 05-06-2023, 05:34 AM. Reason: Added L340-17IRH CopyDMI script
  • jendkkd jeje
    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
    by jendkkd jeje
    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
    10-11-2024, 03:12 PM
  • AHmad_Salal
    Need BIOS Dump/ROM for Lenovo Thinkstation p500
    by AHmad_Salal
    Hello all,
    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
    11-28-2023, 05:28 AM
  • Ahari
    by Ahari
    I...
    Yesterday, 06:12 AM
  • mximiliandz
    help bios lenovo ideapad s145-14iil type 81w6
    by mximiliandz
    Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
    06-20-2025, 06:50 AM
  • hirens
    Lenovo ideapad 3 14IGL05 bios dump needed
    by hirens
    model: 81wh
    sn: pf36ta6h
    board no: nm-c961 gs453/gs553
    hey guys above is my laptop info
    it only blinks the power button kindly help me with a working dump
    old dump attached...
    07-21-2023, 04:48 AM
