toshiba c850
  • amroo2041
    • Jan 2019
    • 4
    • egypt
    toshiba c850
    hi every one
    i have toshiba satellite c850 need bios i tried maybe 5 bios but its different
    some one working power no display some one not working i will upload original file need help please
  • DanielDacko
    • Mar 2015
    • 329
    • Macedonia
    Re: toshiba c850
    Board number?
    I don't provide help for people using CH341A and a clip.
    • amroo2041
      • Jan 2019
      • 4
      • egypt
      Re: toshiba c850
      Originally posted by DanielDacko
      Board number?
      plf/plr/csf/csr uma mb rev 2.1 pcb
      i searched with board number but all file i downloaded not working
      • satishkumar
        • Sep 2015
        • 164
        • India
        Re: toshiba c850
        [quote=amroo2041;1137050]plf/plr/csf/csr uma mb rev 2.1 pcb
        • DanielDacko
          • Mar 2015
          • 329
          • Macedonia
          Re: toshiba c850
          https://www.badcaps.net/forum/showthread.php?t=56249
          https://www.badcaps.net/forum/showthread.php?t=81265
          • amroo2041
            • Jan 2019
            • 4
            • egypt
            Re: toshiba c850
            [QUOTE=satishkumar;1137100]
            thank you for your help its working
            • satishkumar
              • Sep 2015
              • 164
              • India
              Re: toshiba c850
              [QUOTE=amroo2041;1137387]
              • newfoxinformatica
                • Mar 2015
                • 29
                • brasil
                Re: toshiba c850
                cONGRATULATIOSN... Dual bios
                Working ?
                Which one of the duas worked for your model?
                • newfoxinformatica
                  • Mar 2015
                  • 29
                  • brasil
                  Re: toshiba c850
                  [QUOTE=satishkumar;1137401]
                  • englez
                    • Jul 2012
                    • 31
                    • Serbia
                    Re: toshiba c850
                    Dual bios worked,thank you!
                    • aliiash
                      • Jun 2019
                      • 99
                      • england
                      toshiba c850 no power
                      Hi
                      I have toshiba c850 . its was worked ok but there is password on bios . I tried programmed bios chip with a tested file but its stooped of work . I re programmed with old back up file but no power too .
                      I need for help please
                      this is old back up file
                      https://www.badcaps.net/forum/attach...1&d=1674650714
                      • hardware1
                        • Sep 2021
                        • 2949
                        • N/A
                        Re: toshiba c850 no power
                        Originally posted by aliiash
                        Hi
                        Here's your Unlocked Bios, hope it works fine.
                        I think your Backup doesn't work because it was 1KB (300h) larger.
                        all donations are welcome,
                        • aliiash
                          • Jun 2019
                          • 99
                          • england
                          toshiba c850 bios file
                          Hi
                          please please please I need to toshiba PLF/PLR/CSF/CSR UMA MB REV:2.1 bios bin file . I tried to programmed the chip with several different files, but all the files that I downloaded do not match the original file of the device. I would like a test file please .
                          Note : The motherboard contains only one chip. The file size is 4 MB. There is a place for the EC chip next to the main chip, but it is not found .
                          this is original bios file
                          https://www.badcaps.net/forum/attach...1&d=1674932921
                            • 22293
                            Re: toshiba c850 bios file
                            Hi
                            Try the 2nd bios at post #4 .The single version is for win 7 ,the dual is for win 8 .You could use a 2MB chip and flash the dual ones.
                            • Mohammden
                              • Dec 2020
                              • 23
                              • Libya
                              toshiba c850-b098
                              I need bios of motherboard toshiba
                              the motherboard has just one ic bios w25q32
                              • Mohammden
                                • Dec 2020
                                • 23
                                • Libya
                                Re: Toshiba C850 PLF/PLR/CSF/CSR UMB MB REV:2.1 - BIOS
                                i need to fix this bios of c850-a965
                                motherboard plf/plr/csf/csr uma mb rev:2.1
                                • AmeenNeo
                                  • Sep 2023
                                  • 5
                                  • Algeria
                                  i have the same problem and i tried the single version but it did not work , if i try ur second solution and come up with a 2mb chip, what about the resistors around it ?
                                  • TECHO TN
                                    • Jan 2024
                                    • 72
                                    • algeria
                                    [QUOTE=satishkumar;n1661788]Re: toshiba c850
                                    Work thank you
                                      09-06-2024, 05:27 AM
                                    • m1ch43lzm
                                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                      by m1ch43lzm
                                      Hi everyone
                                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                      There's also an extra OTP Secu.R...
                                      09-06-2025, 05:47 PM
                                      09-06-2024, 05:59 AM
