need bios GDC31 LA-K371P rev.3.0
3.4. Dell
Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
Note: There is no publicly available 8FC8 generator available at the moment.
The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcherLeave a comment:
GOOD MORNING PLZ HELP ME TO CLEAN MY BIOS SERVICE TAG IS DK9VH3-8FC8
THIS IS MY OLD BIOSAttached FilesLeave a comment:
hello.
DELL LATITUDE 7520
please fix my dead bios dump or send me a good one.
with the original dump my laptop is dead, no power,no light keyboard, etc.
with other bios have power, light keyboard and rgb collors one by one on the screen.
i attache the original bios.
thank you.
Service Tag: 124FBC3Attached FilesLeave a comment:
hi, can you help me with this problem?
this is the original bios, stuck on logo, i loaded another bios but it says 3 yellow 6 white. there is only 1 bios version that can enter win mini but does not recognize NVME. hope to receive help thanks
sv tag: 124FBC3Attached FilesLeave a comment:
hi i need Re: need bios GDC31 LA-K371P rev.3.0 (a02)
model dell latituted 7420
password unlock helpAttached FilesLeave a comment:
Hello, my BIOS chip is damaged, I bought a new one but it needs a firmware update.
Which one can I use?
Dell latitude 7420
ST: DQPK6G3
LA-K371P REV: 3.0Leave a comment:
HELP ME FIX THE BIOS FILE
Dell latitude 7420
ST: BVPHGK3
LA-K371P REV: 3.0Attached FilesLeave a comment:
Hello i have this dell latitude 7420 won't turn on
ST:HMK66L3
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
