latitude 7410 bios.
  • vwguy0101
    • Jul 2024
    In search of bios for Dell laptop.
    Model ; Dell Latitude 7410
    Board ; FDX40 LA-J261P
    ST ; GCTHN73
    SN ; 35603643567
  • vwguy0101
    • Jul 2024
    The latitude_7410.bin posted by a pervious user worked well for me. I was able to set the service tag up after, everything appears to working normally. Thanks!
    • Al-Umar
      • Jan 2024
      • 34
      • Nigeria
      #63
      Need help on clear me on this Attached bios file
      Dell latitude 7410
      S/T : J3T7GB3
        SMDFlea commented
        Editing a comment
        Thread merged.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      #64
      Dell latitude 7410
      S/T : J3T7GB3
      clean me done
      • Al-Umar
        • Jan 2024
        • 34
        • Nigeria
        #65
        Boss u are much it work fine..
        • Mahesa09
          • Nov 2021
          • 67
          • jakarta
          #66
          hello brother, can you help to clean me
          dell 7410 la-j261p
          st , 87MJ493
            • 21841
            dell 7410 la-j261p
            st , 87MJ493
            Clean the ME firmware ? , remove a password ? .Explain properly what the problem is
            • Mahesa09
              • Nov 2021
              • 67
              • jakarta
              #68
              the late display
              • Markus1741
                • Sep 2020
                • 943
                • N/A
                #69
                try ...
                • shiyab
                  • Sep 2023
                  • 1599
                  • india
                  #70
                  the late display
                  fix csme try
                  • squatty95
                    • Dec 2024
                    • 5
                    • CO
                    #71
                    Hi there,
                    I have a Dell Latitude 7410 with a corrupted BIOS (I assume).
                    Motherboard: LA-J261P Rev 1.0
                    Service Tag: 3LRHQ73
                    BIOS Chip I'm working with is a GD25Q20CT
                    Attached is the bad bin.
                    I've tried writing other binaries to the new chips I have, but the files have all been the wrong size.
                    I need a good bin for that chip so I can get the laptop working again. Would love it to have no BIOS password.
                    I'm new to BIOS stuff, so I don't know much and might be off in my understanding of things. Any help would be greatly appreciated. Thank you so much!
                      • 21841
                      Originally posted by squatty95
                      Hi there,
                      The GD25Q20CT is 256KB. You backed up the wrong chip. Flash that backup you made back onto it, then leave it alone... .Look for the real bios chip. Don`t,don`t,don`t flash anything to any chip until you verify it is the bios chip,and the backup is good.
                      Quote of the day: assumption is the mother of all mistakes​
                      • squatty95
                        • Dec 2024
                        • 5
                        • CO
                        #73
                        Thanks so much for your response. Any advice on how to identify which one of the chips is the BIOS chip?
                        Based on this statement of volatility from Dell, it looks like the one I pulled off (UV32) was the HDMI controller. And it looks like the BIOS chip is the UE1 (MEC5107K-D4-LJ), which is on the bottom of the board. I found a schematic of the board here, and it looks like that's a BGA chip. If that's the case, that's fine. I just bought a CH341A, so I would clearly need something else since that only deals with 24 and 25 series chips.
                        There are references in the schematics to UC5 (25B256DYIG) being a Flash ROM chip, and when I look at eBay listings for the BIOS chip for this MoBo, it looks like it might be that one.
                        But there are various GD25 series chips on the board as well.
                        I apologize, I promise I'm not trying to be a moron. This is just my first time really doing this kind of board-level repair. Thanks for your help.
                          • 21841
                          25B256DYIG
                          • squatty95
                            • Dec 2024
                            • 5
                            • CO
                            #75
                            25B256DYIG
                            Thank you so much, SMDFlea! You're the best.
                            I was able to dump the BIOS, and I've attached it here. Is this correct?
                            Two notes: I actually have two of these motherboards. One with a broken BIOS (I think--it won't POST), the other with a locked BIOS. I don't know which one this is. But they're both the same mobo model.
                            I'm not sure what the issue is with the BIOS. Is there like a standard firmware I can flash to it? Thanks for all your help.
                            • Mahesa09
                              • Nov 2021
                              • 67
                              • jakarta
                              #76
                              can you help me, dell 7410 no display or turning on 5second dad
                              st :CGP1N53
                              • LBTT1121
                                • Nov 2024
                                • 873
                                • Việt Nam
                                #77
                                st :CGP1N53
                                Try
                                1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
                                • Mahesa09
                                  • Nov 2021
                                  • 67
                                  • jakarta
                                  #78
                                  Originally posted by LBTT1121
                                  Try
                                  not work, fan spins fast and no display
                                  • Cepriuko
                                    • Dec 2022
                                    • 26
                                    • Ukraine
                                    #79
                                    Hello, I need to reset the BIOS password. The laptop turns on.
                                    Dell latitude 7410 SRGKV LA-J261P rev A00
                                    ST: 7TP8FB3
                                      • 21841
                                      ST: 7TP8FB3
                                      Read the password guides, you might find a way to unlock it yourself - https://www.badcaps.net/forum/troubl...23#post1622423
                                      • Jeff'sTech
                                        Dell Latitude 7420 BIOS Unlock Gone Wrong
                                        by Jeff'sTech
                                        Hello everyone.
                                        I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                        11-08-2023, 03:30 PM
                                        DELL Latitude 7410 Notebook 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 7410 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7410 boardview and 7410 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7410...
                                        09-06-2024, 08:10 PM
