Samsung NP300E5E-s05ru bios
  • ACS-Repair
    • Feb 2021
    • 203
    I was able to find a BIOS file, I believe on this board, that showed the correct model. I flashed it and it seems to be working OK now.
    I'll include the file I used in case it can help someone else.
  • Forest79
    by Forest79
    07-23-2023, 07:39 AM
  • maanee11
    Help to get Lenovo BIOS bin file for Thinkpad T560
    by maanee11
    Hello Everyone,
    I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
    https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
    In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
    05-15-2022, 11:59 AM
  • Sebastian Codrean
    BIOS file for ASUS F542UN laptop
    by Sebastian Codrean
    Hello to all of you! I need help with a BIOS file.
    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
    02-20-2025, 10:25 AM
  • Fr33man
    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
    by Fr33man
    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
    *Novo button power on
    *Disconnected internal battery...
    09-23-2024, 01:16 PM
  • Kazik
    Samsung NP680Z5E NP670Z5E (mb: NIKE2-15-DC) BIOS file required
    by Kazik
    I received Samsung NP680Z5E laptop for repair. It is charging the battery (charging light on, the voltage on the battery confirms the charging process), but the laptop won't switch on. 3.3V present on the BIOS chip. Power switch checked (however the voltage on the switch is just below 1V - I have no clue if this is the right voltage). Cable connection between the power switch/USB logic board and the main motherboard was checked and is OK. I have no schematic or boardview and I'm also not the greatest specialist in motherboard repair.
    I'm thinking that the NO POWER...
    10-20-2022, 05:38 PM
