Dell Latitude 5410 no power
  • kadsinfo
    • Dec 2017
    • 62
    • maroc
    when starting my pc only gives me an orange light
    i attached my bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Dell Latitude 5410 no power
    i attached my bios
    File read failed. Read it three times, save it as three files.
    • kadsinfo
      • Dec 2017
      • 62
      • maroc
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Dell Latitude 5410
        • zwect
          Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
          by zwect
          I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
          Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
          Here is the original BIOS dump from the 25R256JVEN chip.
          09-11-2024, 05:54 PM
        • lzeta
          Dell Latitude 5410 service tag
          by lzeta
          I have a dell 5410 with locked bios, than I dump bios from a identical laptop and I've flashed it. But now all system information are identical to the bios donator laptop, how can I write again the correct service tag and other infos? I attach the original loched bios bios, how can I extract the right infos? And how can I write it?...
          10-07-2025, 10:19 AM
        • hoarderteks_kyriakos
          Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
          by hoarderteks_kyriakos
          Hello.
          Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
          Here is what happened:
          At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
          10-08-2025, 07:33 AM
        • dlonely94
          Dell Latitude 5591 not power on
          by dlonely94
          Hi everyone!
          I have a Dell Latitude 5591. It has a strange problem:
          First, when the WLAN card is plug in, it will not power on when press power button, even all voltage is up (19v, 3v, 5v, 3valw, 5valw)
          When I remove the WLAN card, it will start nomarlly. Then I power off and re-insert the WLAN card, it still work normally.
          But, if I left it for 3 or 4 days without the battery and adapter plugged in, it will not power on, and I have to repeat the above sequence.
          Sometime, when it not power on, I just unplugged the battery and adapter, wait...
          10-13-2024, 10:29 AM
        • imedbox
          Dell Latitude 5440 no power on
          by imedbox
          ihave the same probleme the labtop want charge with the power supply! my bat is decharged then i can test it with battry it power on!
          i got this after flash bios "XM25QH256C" for removing admin password,i revert to the original then not charge or power on, befor it power on and chargin!
          Any Help !
          her link for Boardview and the Schematic
          Dell Latitude 5440
          bios version : 1.12.20
          MTHERBOARD : IDB40 LA-M401P Rev:1.0(A00) 2023-11-10
          https://www.transfernow.net/dl/20250721QpvcJ0UG
          07-21-2025, 03:03 AM
