Hi guys .... I need bin file for acer swift sf314-59 (sf314-59-53lt)
acer swift sf314-59 Bios request
Re: Bios request
ACER i5 11th gen
model : Swift 3 SF314-59-53LT
Board code : LA-K281P Rev : 1AAttached FilesComment
Re: Bios request
Re: Bios request
There is two IC ... one of them is XMC IC with 16m file and the attached file that you send is didnt work with me .. the other IC is winboand w25q80v with 1024k file and you didnt send it . Which one should i program ??Comment
Acer swift SF314-59(GH4FT LA-K281P NEED BIOS
hello! good day! can i just want to request bios file for
Acer swift SF314-59(GH4FT LA-K281P) need for ec and main chip. 1mb and 8mb chip.. thank you very much for help.Attached FilesComment
Re: Acer swift SF314-59(GH4FT LA-K281P NEED BIOS
DMI 668000 - 669FFF
KEYWIN 6DA000 - 6DA03F
I think he didn't read the bios correctly..what programmer do you have ??Attached FilesLast edited by peste; 06-30-2022, 04:15 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Bios for this model is 16MB. Maybe you have 2 bios chips 8MB + 8MB.Attached Files↵
https://www.badcaps.net/donateComment
by ebyte64Good day.
I would like to request a bios for the following laptop?
Model: Acer P214-52-58CH
Model No: N19Q7
S/N: NXVLHE0H11204BA27600
SNID: 11201936276
Symptoms: Laptop powers on but no picture on screen.
I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...-
Channel: BIOS Requests ONLY!
09-25-2024, 05:59 AM -
by Wg188I have an Acer veriton Z4660G all in one pc,
Model: Z4660G-I5850H1 (VZ4660G_W)
Need bios dump and schematic would save my life !
to make a long story short I bought this all in one used
with a broken lcd, with the objective of making a custom desktop out of it
,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by tekknoohello guys, my laptop stuck black screen at power on. this caused by bios version downgrade. laptop works well with 1.14 ver bios. but cpu stucked at 399mhz, then i downgrade it from official 1.06 version with using acer official bios by modifying platform.ini files flags. then computer rebooted and bios flashed on post screen with succeed then re reboot and stuck at black screen.
i tried to re-program bios chip from *.fd bios file with CH341 programmer but i can not succeed.
please guide me how to fix that
SNID: 93900110266
SF314-56-30U1-
- Loading...
