zed air gra
  • krogs214
    • Sep 2017
    • 84
    • Philippines
    zed air gra
    hi anyone can help me
    i need bios of zed air gra
    this is may old bios
    keyboard.touchpad and usb port not working
  • krogs214
    • Sep 2017
    • 84
    • Philippines
    Re: zed air gra
    Part no. Il 1406g.232wagrvci
    • peste
      • 13451
      • ROMANIA
      Re: zed air gra
      try..
      • titomno2
        Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
        by titomno2
        Hi guys,
        On motherboard ACER AN515-52 type LAF951P.
        I fixed issue with not starting computer (it was the PQ201 component not working properly).
        But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
        Basically some HDD spin but are not detected by the bios.
        Already tried following:
        checked the 4 data lines
        #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
        #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
        07-28-2024, 08:30 AM
        by Vesko356
        08-11-2023, 03:27 AM
      • joven016
        Lenovo Ideapad S145 need working bios HELP!!
        by joven016
        Problem is blinking power led only
        i don't know exactly if it's s145-15igm or s145-14igm
        have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
        Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
        Already tested some of posted bios here
        S145-14igm - success but invalid serial and not booting on OS
        S145-15igm - success with serial and some other info in bios but still not booting on OS
        already tried installing new windows but always booting on bios setup
        windows installer flash drive detected on...
        08-21-2025, 10:55 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Sparklingx
        CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
        by Sparklingx
        So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
        So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
        now all...
        08-29-2024, 01:53 PM
