Need a Fixed Bios for Thinkpad E590
https://www.badcaps.net/donate -
Re: Need a Fixed Bios for Thinkpad E590
Does anyone can solve we cant go bios ..
0271: Check Date and Time settings.
0183: Bad CRC of Security Settings in EFI variable.Comment
kordex35 solve ..
PAtched bios ...
https://www.badcaps.net/forum/attach...6&d=1678551913Comment
E590 clear bios
I try alot of bios but one of them can open .. but it is very late signal
Can someone clear this ..
Thanks a lotAttached Filesif you find these attachements useful please consider making a small donation to the site
Here is clear bios .. Hexfex from turkiye solved .. thankss ..Attached Filesif you find these attachements useful please consider making a small donation to the site
.Comment
Hello. I have problem with my E590. I accidentally disconnect laptop from charger during BIOS restarts, and now it's bricked. 🤦♂️
When I connect charger, power button LED blinking 3 times shortly, but when i try to turn on, the LED blinks longer 3 times and stays on. Power consumption is 0.080 - 0.100A.
I tried few BIOS from forum but doesn't change anything, still the same LED sequence.
Laptop is
Lenovo Thinkpad E590
Mobo: NM-911 rev 1.0
Type: 20NB-002BMH
S/N: PF-1JS76S 19/06
Intel I5-8265U (SREJQ)
I also changed bios chip to another from VSCC list but still the same thing.
Of course I made backup of ori bios.
If someone can repair my BIOS dump, would be grateful.
Thank you
Thread merged.
Before making a new thread please read the rules first, so I don't have to move your request at the existing topic again:
You MUST:- Post under a related thread if it exists
I have an older Lenovo Thinkpad E590 for which I unfortunately forgot the BIOS password I used.
I managed to read the bios with the CH340A. There are a few videos circulating on the Internet in which the password is decrypted - unfortunately I couldn't find it at this point in the dump.
What options do I have to reset the bios password?
I have attached a dump of my bios.
Notebook type:
Lenovo ThinkPad E590
20NB-CTO1WW
S/N: PF-1NTXHP
Mainboard: MN-B911, Rev. 1.0
It would be great if someone could help me.
Unfortunately, Lenovo doesn't have .bin files.
I've already searched online - but haven't found anything suitable.
Thank you!
Andreas
read bios chipset again, it has errors. read it 3-4 times and compare results, when you have 2 identical it means you have a good backup.Hello everyone,
Notebook type:
20NB-CTO1WW
S/N: PF-1NTXHP
Thank you!
Andreas
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
So, I've read it several times and compared it.
Now both the CRC is correct and Diff says the dumps are the same.
I hope this file fits now.Attached Filesif you find these attachements useful please consider making a small donation to the site
I have now created a patched version of my bios dump using the Lenovo Autopatcher.
Unfortunately, the notebook only emits a few beeps when starting up and otherwise only has a black screen (according to the Lenovo app: Error 285 - function-related TCG compliance problem).
With the patched Bios-File the notebook is not working :-(
Then I reset the TPM module (clear-tpm -useppi), which i have read in one Thread.
I then re-flashed the original bios dump - then the notebook works again - but unfortunately with the bios password.
Does anyone have any other ideas what I can do to remove the password?
Kind regards:
AndreasComment
follow steps from autopatcher.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by volinakis; 03-01-2025, 11:40 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
I need patched bios..Please help me ..
I try with autopacher but didnt work.. Can you help me
thinkpad E590 ,NM-B911 rev 2.0
sn:pf-1nstqk
there is a passwordAttached Filesif you find these attachements useful please consider making a small donation to the site
hi, i have a lenovo tp00095c/type 20nb/sn PF-1NMDY7 with flash keyboard,caps and num lock light blocked...can anyone help me with bios?i have the original file..thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
sorry...
LENOVO THINKPAD
ltp00095c
type 20nb-0029IX
S/N PF-1NMDY7
motherboard FE490/FE590/FE480 NM-B911 Rev:1.0
https://www.badcaps.net/donateComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by akwkyHi!
Incidentally, Windows 11 have recently started auto-flashing computer BIOS in our region. Even more suspiciously, Lenovo has released a BIOS update just few days before the PC was trashed. About a week later, the BIOS update image has been oficially marked...04-14-2025, 01:56 PM -
by MaxonDomkratHi everyone.
I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...-
This specification for the Lenovo ThinkPad E590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E590 boardview and E590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 02:28 PM
- Loading...
