Lenovo Thinkpad E495 help unlock
  • hoaca388
    Badcaps
    • Jan 2022
    • 11815
    #41
    Re: Lenovo Thinkpad E495 help unlock
    Originally posted by Pappamental
    Thank you!
    Tested it but still same error, black screen and caps lock LED is always on.
    Did you replace the NVRAM with the one from the original Lenovo BIOS as hardware1 did and explained in post #23?
    Serial number ?
    • Pappamental
      • Sep 2023
      • 5
      • Norway
      #42
      Originally posted by hoaca388
      Serial number ?
      S/N: PF-1V5R0V
      Bought in country: Norway
      Thanks a lot for helping! <3
      • hardware1
        • Sep 2021
        • 2939
        • N/A
        #43
        Can you please help me autopatch and possibly replace NVRAM on my attached original BIOS dumpfile from my Thinkpad E495 Ryzen?
        I tried the autopatcher 0.2 but I get no POST, i.e. black screen and caps lock LED is always on. So it looks like i need the trick in post #23.
        Thanks all over the place in advance!
        I think this will works fine, try it.
        all donations are welcome,
        • Pappamental
          • Sep 2023
          • 5
          • Norway
          #44
          It sure did!
          Thanks a million for great help hardware1, you're spot on with a fix again!
          Made a little donation to show my appreciation.
          Have a really nice weekend!
          • hardware1
            • Sep 2021
            • 2939
            • N/A
            #45
            It sure did!
            You're welcome. We appreciate your support too.
            • Ruzal_05
              • Mar 2017
              • 14
              • Ukraine
              #46
              Good afternoon, I ask for help in unlocking the BIOS
              • Ruzal_05
                • Mar 2017
                • 14
                • Ukraine
                #47
                thank you, the issue is resolved
                • Size
                  • Nov 2022
                  • 4
                  • Russia
                  #48
                  Can someone help me unlock ThinkPad E495.
                  SN: PF259Qs8
                  TYPE 20ne-s1yt00
                  Martherboard nm-c061
                  This is my backup bios.Thanks!
                • Size
                  • Nov 2022
                  • 4
                  • Russia
                  #49
                  I've reformed I apologize​
                  • Size
                    • Nov 2022
                    • 4
                    • Russia
                    #50
                    Didn't wait for help
                    The password is in the EC controller.
                    I dropped it and read the dump.
                    I cut out a piece based on the look from the official dump.
                    I asked for it.
                    Moved the DMI block. Located at the very bottom.
                    Works.
                    I am attaching the firmware for the EC controller.
                    • redbaron1007
                      • Jun 2021
                      • 107
                      I've got a lenovo thinkpad E495 that originally wasn't turning on and was acting like a bios issue. The battery was charging when the charger was plugged in and the laptop would act like it was starting and get stuck at a black screen with the backlight turned on. I tried reflashing the bios with a file I found on another thread on here when I searched for E495 bios ( I included the bios file below as well as the original bios I read from the chip). When I replaced the bios chip I got the lenovo logo screen to show up and was able to start the self test diagnostics and everything except the mouse came back as a pass ( the mouse failed because I forgot to plug it back in).
                      I exited the diagnostics and threw in an ssd with windows on it to see if it would boot to it and after the lenovo logo I got the error
                      0183 Bad CRC of security settings in EFI variable
                      Press F1 to enter setup.
                      Click image for larger version  Name:	IMG_20240504_164421806.jpg Views:	0 Size:	3.02 MB ID:	3265030
                      I pressed F1 and it went to a blank screen with the backlight turned on. I left it for about 10-15 minutes and when I came back it was still at the blank screen. I pressed the power button and it shut off immediately. When I restarted the laptop I tried pressing F1 at the logo screen to get into the settings menu and got the same error message and then the black screen again.
                      I haven't tried any other bios files because I couldn't find them anywhere and I can't tell if this is still a bios issue or if something on the motherboard isn't communicating with something else properly.
                      Also not sure if this belongs here or if it needs to go into the bios request section since I'm not sure if it's a bios issue anymore.
                        • 21040
                        Post the serial number - https://www.badcaps.net/forum/troubl...before-posting
                        • redbaron1007
                          • Jun 2021
                          • 107
                          The serial number is PF1WKTF5
                          • qayyum786
                            • Aug 2018
                            • 1933
                            • INDIA
                            #54
                            Try extracted from lenovo support
                            • redbaron1007
                              • Jun 2021
                              • 107
                              The file worked great. Thank you.
                              • potrebitell
                                • Feb 2021
                                • 14
                                • Bulgaria
                                #56
                                Hello everyone!
                                Can someone help me unlock my Lenovo ThinkPad E495? Patcher not working - cmd closes immediately after opening.
                                I attached my backup bios.
                                Thanks!
                                • potrebitell
                                  • Feb 2021
                                  • 14
                                  • Bulgaria
                                  #57
                                  Sorry in my previous post the file was not uploaded correctly...
                                  • peste
                                    • Dec 2016
                                    • 12887
                                    • ROMANIA
                                    #58
                                    read the rules..https://www.badcaps.net/forum/troubl...before-posting
                                    post the S/N,, the motherboard model, etc.
                                    • potrebitell
                                      • Feb 2021
                                      • 14
                                      • Bulgaria
                                      #59
                                      Sorry for that.. I forgot to post the MB number.
                                      MB:FE495/FE595 NM-C061 Rev 1.0
                                      I will try to upload the dump again (sometimes it return an error: {path}.. is not writable). On my last post it says: Invalid File Specified
                                        SMDFlea commented
                                        Editing a comment
                                        Don`t choose the OTP chip.
                                    • potrebitell
                                      • Feb 2021
                                      • 14
                                      • Bulgaria
                                      #60
                                      Ok. I export a new dump but it gives me this error when uploading.
                                      PS: Even I can't upload images... errorClick image for larger version
                                        Lenovo ThinkPad ThinkPad E495 Notebook E Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad ThinkPad E495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E495 boardview and ThinkPad E495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 08:44 AM
                                        Lenovo ThinkPad E495 Notebook E Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad E495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E495 boardview and E495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                        09-06-2024, 02:28 PM
                                        09-06-2024, 12:36 PM
