Lenovo Thinkpad E495 help unlock
  • ffake41
    • Aug 2021
    • 10
    • Poland
    Re: Lenovo Thinkpad E495 help unlock
    Here's your patched file, hope it works fine.
    ok thx i try and give answer
    • ffake41
      • Aug 2021
      • 10
      • Poland
      hmmm its working Thank You very much , what software You use to patch ?? Autopather 0.2 ??? i try use autopatcher 5 times , all patching good but laptop start with only black screen and nothing happend.
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        I have used AutoPatcher as usual, after that I replaced the NVRAM with the one which is inside of the official bios file (Downloaded from Lenovo).
        all donations are welcome,
        • ffake41
          • Aug 2021
          • 10
          • Poland
          Thanks again for your help, everything works fine. Well, thanks for the explanation, because I already thought maybe I had something wrong with Python.
          • vvrabel
            • Mar 2023
            • 4
            • Ukraine
            Please, help me unlock Supervisor Password on ThinkPad E495,
            dump bios
            Thanks.
            • hardware1
              • Sep 2021
              • 2946
              • N/A
              #26
              dump bios
              Thanks.
              Your Backup Footer not good, try to read the Chip again correctly.
              • vvrabel
                • Mar 2023
                • 4
                • Ukraine
                #27
                there is no good backup.. programming another e495 pached dump.. now only a black screen, Caps Lock and nothing else .. how can I restore this notebook?
                • hardware1
                  • Sep 2021
                  • 2946
                  • N/A
                  #28
                  Try this Virgin file and see if the device will works or not.
                  Ignore the Password for now.
                  • vvrabel
                    • Mar 2023
                    • 4
                    • Ukraine
                    #29
                    good
                    result..started
                    • hardware1
                      • Sep 2021
                      • 2946
                      • N/A
                      #30
                      good
                      result..started
                      Now to remove the Password, you should to use thit Patched file and follow the steps Carefully.
                      [ HOW TO USE THE PATCH ]
                      STEP 1: Flash and replace current BIOS with the generated patch file
                      STEP 2: Boot the machine
                      STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                      STEP 4: Enter any character when asked for Supervisor Password
                      STEP 5: Press enter when it shows Hardware ID
                      STEP 6: Press space bar 2x when asked
                      STEP 7: Turn off machine
                      STEP 8: Restore original BIOS
                      STEP 9: Reset BIOS settings to factory default
                      [ NOTES ]
                      When booting the patched BIOS you might have to:
                      - Hold the anti-tamper switch down the whole time (use tape)
                      - Remove the hard disk or replace it with a locked one
                      At step #8 you can use the file in Post #28 as your Original BIOS.
                      • vvrabel
                        • Mar 2023
                        • 4
                        • Ukraine
                        #31
                        [ NOTES ]
                        Thank you so much for your help, everything works fine!
                        • hardware1
                          • Sep 2021
                          • 2946
                          • N/A
                          #32
                          Good to know, You're Welcome.
                          • marcoalvarez
                            makiabelo
                            • Jul 2021
                            • 19
                            • My house
                            #33
                            HELP I have a problem but my laptop is E595 I think they are very similar I don't know if the dump is the original one it already came unsoldered, but it has a failure that doesn't turn on they could repair it and also remove the password or send me a bios with a patch and then I put it my bios
                            • outsider
                              • Apr 2014
                              • 104
                              • localhost
                              #34
                              Hello
                              Can anyone help me to remove password from Lenovo ThinkPad E495? I tried to delete using Autopather 0.2, but after turning on the laptop, I have no image on the screen. Attached is the original BIOS dump file.
                              Thanks!
                              • volinakis
                                • Jan 2021
                                • 2872
                                • N/A
                                #35
                                Originally posted by outsider
                                Hello
                                Thanks!
                                try and follow steps described in autopatcher [ HOW TO USE THE PATCH ]
                                • outsider
                                  • Apr 2014
                                  • 104
                                  • localhost
                                  #36
                                  volinakis
                                  Thanks a lot, it works!!!
                                  What could be wrong in my case? Did you use autopatch on macOSX?
                                  • volinakis
                                    • Jan 2021
                                    • 2872
                                    • N/A
                                    #37
                                    volinakis
                                    read post #23.
                                    • Pappamental
                                      • Sep 2023
                                      • 5
                                      • Norway
                                      #38
                                      Can you please help me autopatch and possibly replace NVRAM on my attached original BIOS dumpfile from my Thinkpad E495 Ryzen?
                                      I tried the autopatcher 0.2 but I get no POST, i.e. black screen and caps lock LED is always on. So it looks like i need the trick in post #23.
                                      Thanks all over the place in advance!
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12278
                                        #39
                                        Originally posted by pappamental
                                        hi,
                                        can you please help me autopatch and possibly replace nvram on my attached original bios dumpfile from my thinkpad e495 ryzen?
                                        I tried the autopatcher 0.2 but i get no post, i.e. Black screen and caps lock led is always on. So it looks like i need the trick in post #23.
                                        aaaaaaaaaa
                                        • Pappamental
                                          • Sep 2023
                                          • 5
                                          • Norway
                                          #40
                                          Originally posted by hoaca388
                                          aaaaaaaaaa
                                          Thank you!
                                          Tested it but still same error, black screen and caps lock LED is always on.
                                          Did you replace the NVRAM with the one from the original Lenovo BIOS as hardware1 did and explained in post #23?
                                            Lenovo ThinkPad ThinkPad E495 Notebook E Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad ThinkPad E495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E495 boardview and ThinkPad E495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 08:44 AM
                                            Lenovo ThinkPad E495 Notebook E Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad E495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E495 boardview and E495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 02:28 PM
                                            09-06-2024, 12:36 PM
