Dell Inspiron/Vostro 5402 5502
  • zsi3ug4z
    • Aug 2022
    • 57
    • việt nam
    Originally posted by hoaca388
    Inspiron 5402/5409
    Service Tag: 7S3QG63
    phát đầu bình thường phát sau lại bi a ạ. Con này hình như k có ic tpm khoai thật
    • peste
      peste commented
      Editing a comment
      in English please..
  • lavie
    • Aug 2015
    • 90
    • southafrica
    Please help me fix no display
    SERVICE TAG 5R3YW93
    VOSTRO 5402
    • danito
      • Jun 2016
      • 1098
      • Romania
      SERVICE TAG 5R3YW93
      VOSTRO 5402
      Try
      • lavie
        • Aug 2015
        • 90
        • southafrica
        Originally posted by danito
        Try
        thanks didnt work but i one online working but cant saved service tag
        • mahlon simwnaja
          • Nov 2022
          • 84
          • south africa
          Good day
          Anyone! please help repair this BIOS files.
          FAULT: NO DISPLAY
          SN: CT82T93
          MB N0: MB-V TGL 8L MB 19862-1
          • danito
            • Jun 2016
            • 1098
            • Romania
            #26
            try
            • jags46
              • Mar 2022
              • 11
              • República Dominicana
              #27
              DELL VOSTRO 5502 CLEAN BIOS PLEASE
              • LBTT1121
                • Nov 2024
                • 1052
                • Việt Nam
                #28
                hi, try and feedback , only bios 8Mb
                • jags46
                  • Mar 2022
                  • 11
                  #29
                  working thanks
                • f-bone
                  • May 2013
                  • 96
                  • Greece
                  #30
                  hi from me too!
                  I mistakenly posted this in the wrong thread (different model) so here we go:
                  can you please repair this bios dump? gives backlight and nothing else - there is bitlocker on the sdd so maybe we can save the data
                  ST: 5ST4P93
                  EX: 12625892823
                  motherboard: 19862-1
                  It must be Vostro 5502 (the damn thing has not "model" label so I uploaded a pic)
                  I tried other dumps (from 5406/7502 I think as I was in that thread earlier), a few would not save the ST or exit manuf. mode and one from above that worked does not see the nvme. Keyboard/trackpad also don't work but maybe that's a different issue.
                  thank you in advance!
                  • peste
                    peste commented
                    Editing a comment
                    post merged ..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                • peste
                  • Dec 2016
                  • 13653
                  • ROMANIA
                  #31
                  Originally posted by f-bone
                  hi from me too!
                  ST: 5ST4P93
                  EX: 12625892823
                  post full name and model, motherboard model,
                    • 21960
                    hi from me too!
                    ST: 5ST4P93
                    EX: 12625892823
                    Try these. Flash both. Vostro 5502
                    • f-bone
                      • May 2013
                      • 96
                      • Greece
                      #33
                      ok just tried them but I get no image, fan came on a couple of minutes later, the power led turns on white, stays for a few secs and fades out, repeat - caps lock led also on all the time.
                      using known good ram in single/both slots
                        • 21960
                        Re-check your soldering, give it at least 5-10 minutes to boot
                        • f-bone
                          • May 2013
                          • 96
                          • Greece
                          #35
                          soldering double checked under the microscope and still loops, white led on -> off -> on and so on...
                          • LBTT1121
                            • Nov 2024
                            • 1052
                            • Việt Nam
                            #36
                            try
                            • f-bone
                              • May 2013
                              • 96
                              • Greece
                              #37
                              Originally posted by LBTT1121
                              try
                              unfortunately I get the same - white led on -> off -> repeat... but I found a working set 8/16mb (everything works: keyboard, trackpad, nvme) but it won't save the Service Tag and keeps turning on to Manufacturing Mode.
                              is it possible to:
                              1) make it save ST
                              2) transfer bitlocker keys from original non-working dump? now that it sees the nvme it asks for bitlocker key, the owner didn't know they had bitlocker enabled
                              attached is the "semi"-working bios
                              thank you so much for your efforts guys, I'd be happy to buy beers!
                                • 21960
                                is it possible to:
                                1) make it save ST
                                Try these, flash both. Bitlocker keys are not stored in the bios, the owner will have to log into his microsoft account to recover the key.
                                • f-bone
                                  • May 2013
                                  • 96
                                  • Greece
                                  #39
                                  unfortunately this also causes the same behavior i.e. white led on->off->repeat only difference I now have full fan spin which your previous files didn't bring up (noticed that when a bios gives image the fan is indeed spinning fast so this is normal).
                                  I tried the "working but not saving" bios I mentioned before, then downloaded the official bios from DELL, flashed it using a USB which completed successfully and NOTHING CHANGED... Im going to hang myself in the lab (soldering disoldering the chip one of the legs broke and I had to use the grinder, resolder it under the microscope and reinforce it with uv glue - now I only use hotair - the chips cannot be programmed onboard as I tried with clips AND the spring-loaded pin adapter for SOIC). So after successful update through USB, the Service Tag still cant be saved.. other changes to BIOS settings are stored successfully i.e. disable virtualisation etc. If you guys are willing to give up I totally understand.
                                  Click image for larger version  Name:	Update .jpg Views:	0 Size:	2.79 MB ID:	3584955
                                  • f-bone
                                    • May 2013
                                    • 96
                                    • Greece
                                    #40
                                    ok today I even tried to write ST with cctk under WinPE and that wont stick either... I get some error message and ST is not saved
                                    error "CoCreateInstance() failed for locatorGetWMISMBIOSTable: NULL pointer to SMBIOS Entry specified.GetWMISMBIOSVersion: null pointer passed as pSmbios."
                                    I am depressed.
                                      DELL Inspiron 5502 Notebook 5000 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 5502 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5502 boardview and 5502 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5502...
                                      09-07-2024, 03:10 AM
                                      09-07-2024, 02:50 AM
