Bios Asus N75SF REV 2.2
  • antppe
    • Nov 2021
    • 24
    • Italia
    This file was saved from an asus K75sf. This is the original motherboard file. It is not a dump file. Main Board rev 2.2
  • antppe
    • Nov 2021
    • 24
    • Italia
    Re: Bios Asus N75SF REV 2.2
    Error file asus n75sf
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • Sebastian Codrean
      BIOS file for ASUS F542UN laptop
      by Sebastian Codrean
      Hello to all of you! I need help with a BIOS file.
      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
      02-20-2025, 10:25 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • kodox
      Asus ExpertBook B1400CB Bios Dump Needed
      by kodox
      need original bios dump, original bios has flashed by other technician before me.
      attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
      unit info:
      Model: Asus ExpertBook B1400CBA-0711A1235U
      S/N: R6NXNZ006657238
      CN: 7F6F
      Mainboard Code: B1500CBA R2.1...
      08-16-2025, 12:20 PM
