Dell Latitude 5520 Bios Password unlock
    Re: Dell Latitude 5520 Bios Password unlock
    pls remove bios password
    thk
      thk
      There is no file attached
        Originally posted by hoaca388 View Post
        Check the chip soldering process, flash bios. Unlock operation is correct.
        I check everything and still have problem to start. Blinking 3 amber 6 white light and turn off.
          Are you using a clip? Do not rely on it. If not, your backup should always work, try flashing it back. If same symptoms, then check for moved or missing components nearby. Check voltages, start at leg/pad #8 of BIOS chip, should be 1.8v or very close for new laptops. Do not press on bios chip when soldering, it might "squirt" solder to nearby pads if it is too much. I reach the same identical file as hoaca388 when unlocking.
            chip has 3.3v, is soldered good, I dont use clip, my file was from mrwab
              I checked it too, procedure is correct, I reach an identical file. Desolder and verify that the flashing was good? Try your backup, it should work always.
                @Mazorca Please could you help unlock this BIOS Admin password on a Dell Vostro 3590 (E7A8) please? I would be very grateful..
                Thanks in advance
                  Thanks in advance
                  https://beta.bios-pw.org/
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Have tried bios-pw.org and the codes do not work
                      Thanks hoaca388 - tried bios-pw.org and the codes do not work. As this is E7A8, I believe bios-pw.org will not work on the admin password lock
                        Note that the keyboard to enter the password must be Qwerty US layout (can use an external keyboard via USB 2.0 port). For uppercase letters, use the Capslock key.
                          I stand corrected Sir... Just tried with an external US keyboard and code worked perfectly. Thank you for your help, much appreciated.
                            hi the team, Please unlock 5520 bios
                              UNlocked
                                UNlocked
                                All my gratitude sir
                                  heloo.
                                  my dell latitude 5520 have a password (master password)
                                  can you help me with password please. Dell 8fc8
                                  Thanks in advance
                                    Originally posted by darckreign1984 View Post
                                    heloo.
                                    Thanks in advance
                                    i tried diferent file patched, using me region from my bios, did not work
                                      heloo.
                                      My dell latitude 5520 have a password (master password)
                                      thanks in advance
                                      feedback
                                        Originally posted by miansh621 View Post
                                        feedback
                                        you do the magic.
                                        your file worked.
                                        thanks
                                          Hello I need help to unlock my laptop bios. Please I have Dell Latitude 5520 also. What should I send you ? And how to flash a file bios ?
