Dell Latitude 5520 Bios Password unlock
    Re: Dell Latitude 5520 Bios Password unlock
    Originally posted by jatoi View Post
    plz rebuild this bios
    can any one help
    what's your issue !
      laptop no power
      an other bios work but error
        Hello, could you unlock this bios and disable Absolute
        service tag: G2HG2B3
          1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode. Let it run for 2minutes, it will restart several times with no display.
          all donations are welcome,
            thanks, it works!
              please i have a dell latitude 5520 11th Gen with password, Please i need help to clear the password..
              Here is my dump....Thanks
                  Alright let me try and give you feed back
                    thank you so so much... Password cleared..
                    I appreciate you alot,God bless you..:
                      help i need to unlock bios
                      Last edited by Vesko356; 08-01-2023, 04:45 PM. Reason: Bios removed, thread hijack.
                        your model is 5320 and you already posted the same bios in Latitude 5320 thread. Read rules to avoid banning.
                          Dell latitude 5420
                          Can someone help me with a clean file?
                          I dont get though why this file is so small.
                          Chip is Winbond 25R256JVEN. SHould this not be 32mb or so?
                          It has been verified and read twice .
                          It was read however on the board with insulated wires soldered to the programmer
                          edit..ok here is what I believe is the correct file..
                          I used asprogrammer this time.
                            Originally posted by vikivng View Post
                            Dell latitude 5420
                            bad backup file the real size 32mb not 8mb
                              It should be 32MB. The dump from this chip must be 32MB not 8MB, so you doing something wrong for sure. Did you choose the right chip within the programmer software?
                              Become a Badcaps supporter
                              Thanks to all supporters.​
                                thnx guys I have re read with asprogrammer and have updated the file..pls check
                                  Yep, much better result this time.
                                    thnx is this the cleaned file.?
                                      It's a password free file, that's what you want, isn't it?
                                        yes thnx..much appreciated
                                          You're welcome. Be careful with the programming of the dump back to the chip, use verification. I suppose you know how to proceed after the first boot, if not read some previous posts, for example post #307.
