read..https://www.badcaps.net/forum/troubl...before-posting
Post the full name and model of the laptop, S/N, etc...
HP BIOS unlock tool
I tried to remove password protection from the various info, but was not able too.
Attached Files -
I would like to thank you for this program. It works and helped me with unlocking BIOS.Leave a comment:
Hi there!
I have a hp elitebook 745 g4 and need the bios password removed can you help me?
Which chip do I need to reprogram U366 or U365?Leave a comment:
Attached FilesLeave a comment:
Today I have already unlocked several laptops of this model, but the problem is only with this one. Previously, I left the BIOS file from the ISSI chip, add one from Winbond 256 to the archive. I've already tried everything I can.
Hello. help me please. I have a HP 850 g5 with a BIOS password. There was also added fingerprint unlocking. I took a dump to unlock it, ran it through the HP Unlock tool, but it didn’t remove the password. Then I tried the same thing through HP Unlocker - also nothing. I tried to do the same with the chip winbond 256 - the message about the possibility of unlocking with a finger disappeared, but the code was never deleted. Help me please. Here I give you a dump.
HP 840 G5
5CG838421QAttached FilesLeave a comment:
HP 840 G5
Read the rules before posting.Post in an existing thread (use forum search) ,you MUST post the PC serial number etc -> https://www.badcaps.net/forum/troubl...before-postingLeave a comment:
can help unlock this HP pro mini 400 G9 Desktop pc , i try with unlocker but my file is 32mbLeave a comment:
You are not making these solution clearly, I want you to show me which string in the bios file contains the password, and I want to know how to used updated bios file and the dump locked file to compare and remove the password, just want to know how to do it in all laptop models, thanks, am waiting for your response great engineers.
https://www.badcaps.net/forum/troubl...59#post1859659Leave a comment:
You are not making these solution clearly, I want you to show me which string in the bios file contains the password, and I want to know how to used updated bios file and the dump locked file to compare and remove the password, just want to know how to do it in all laptop models, thanks, am waiting for your response great engineers.Leave a comment:
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by mohamedbalwehello everyone
i need bios dvr DS-7204HQHI
motherboard code 80303-p rev 2.2
The attached file is lock pass...07-14-2025, 06:02 AM -
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
