HP BIOS unlock tool
Re: HP BIOS unlock tool
Originally posted by Stevedb View Posthi vesko
here is dumpCode:File does not contain Intel Engine firmware
Last edited by Vesko356; 02-25-2020, 01:31 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
It's not a corrupted file, it's a RAR archive without extension inside another RAR archive. Absolutely makes no sense, you have to do this on purpose so that it makes it harder for us and makes us lose time…
PS: my nickname doesn't have a capital letter, I know it's aggravating.Last edited by piernov; 02-25-2020, 01:35 PM.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
There is a reason we ask for your dump. We can also find random dumps on the web that don't work and spend our time unlocking them for nothing… Not to mention the additional time required to clean ME, and the headache with DMI info and compatibility issues.
EDIT: Ah sorry now I understand, it's Equinox' dump that himself didn't manage to get unlocked… I think he can get on here by himself so that you don't look like an idiot instead of him.Last edited by piernov; 02-25-2020, 02:31 PM.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Thank You RethoricalCheese, I downloaded the tool and cleared the original BIOS. I am running some tests. However I have an issue when verifying as te software is returning mismatch between buffer and memory. I talked about this issue in another thread....just for info.
Originally posted by vince59 View PostThank You RethoricalCheese, I downloaded the tool and cleared the original BIOS. I am running some tests. However I have an issue when verifying as te software is returning mismatch between buffer and memory. I talked about this issue in another thread....just for info.
Well that is a problem with your programmer or the way you try to program.
Might need to unsolder chip from board and program it then.
Hey, the chip is desoldered.
Right now I am testing with a W25Q128FV (SOIC 8 package) but I will have to flash same chip with a different package (WSON 6x5).
Let'us stay on current issue. I tried EZP2019, TL866II plus and CH341a (black) with different softwares and different notebooks, I also used a NBook I dedicate to Ubuntu.
I ma quite sure I am not doing mistakes but I am going mad trying to understand where the problem is.
I can not test the file over the MB as I am waiting to get shipped wson chip.
Do you have any "particular" aspect/advise I should pay attention/observe during flashing procedure?
Thank You for your help
PS: last test (right now) with colibri programmer software and ch341 gave me only one value mismatch as follows:
address: 0x00B555D9 buffer data: 0xAE device data: 0x8ELast edited by vince59; 02-29-2020, 08:04 AM.
Hello all and RethoricalCheese.
I want to inform that tool given to us from you Working Very well. Last week i unlocked HP Probook 4340S with full success from dump CH341 programmer even without desolder. Somwhere readed that the best metod to power on with plug charger without battery then power off.
Best regards and luck RethoricalCheese. Greetingz from Poland
ok, i'm dumb! how is this tool works? i am using windows 10 and try to execute the file and i get an error. fatal error Filed to execute HPUnlocker...
file is in c:\
and of course i drag the dump over the hpunlocker.exe file, nothing happens... i tried a few files on this forum too... but nothing is changingLast edited by justin35; 03-07-2020, 10:15 AM.
working!!! i got the new file and now it's programming ic.
i had to move the file to my other partition as it didn't have enough privileges
FOR ALL OF YOU THAT DOESN;T HAPPEN ANYTHING WHEN YOU DROP THE BOIN ON THE EXE FILE:
DO NOT PUT THE HPUNLOCKER.EXE FILE IN C:\ USE D:\ OR ANY OTHER DRIVE BECAUSE C DRIVE NEEDS SECURITY ELEVATION IN ORDER TO ACCESS AND WRITE FILES THERE!!!
