HP BIOS unlock tool
    Re: HP BIOS unlock tool
    I just did it alone, downloaded the hp unlocker (under the 1st page of the treat) and just drop my bin and it worked like a charm, thks for your help ;-)
    My laptop works again
    If my bin unlocked can help another one
      Good job!
      Everybody should use their own dump files, otherwise there could be problems like errors, slow boot or wrong dmi information like serial number.
        short question, this tool only removes the password and does not touch anything else in the BIOS dump ?
        Best,
        hallo51
          Best,
          hallo51
          Еxactly.
          Become a Badcaps supporter
          Thanks to all supporters.​
            Hell i have created dump with ch341a programmer
            then unlocked with this unlock tool flashed it back but now only fans spin at full
            speed and nothing on the screen i have attached files can someone please check .
            Thank you
              Thank you
              Because sadly your dump is missing most of its content.
                What to do now?
                  How could that happen programer was reading ok just had some write timeout error in programmer software but after couple times it was writing fine. Any ideas why that happened?
                    It had nothing to do with writing. When you read eeprom content, some of the information was lost. Didn't you verify your dump?
                    You need a working dump from somewhere with clean ME. Not sure about this model but with some models, there is DMI information on EC bios so when you program main bios with wrong information, it will automatically replace it with correct information.
                    HP bios can get complicated, I am having trouble myself with some models.
                      this is Elitebook 1030 G2 when i reed chip i just made 3 backups thats all i have attached other 2 how can i check if they are good or bad ? also which is the main bios because i was flashing 16mb chip but there is also 8gb one
                        I can confirm this tool works also for the elitebook 1040 x360 G6
                          You can't read it anymore because you already wrote a faulty dump on it. Basically deleted some of the content.
                          Try this:
                            Try this:
                            Now i have 3 long beeps and 2 short
                              Try this:
                              i have flashed bios with that file verified its matching but now laptop boots up keyboard flashing and after its producing 3 long and 2 short beeps fans starts to spin at full speed nothing else black screen also have tried different bios files from other forum members same thing. Any ideas what to try next?
                                No idea, sorry. Make a new topic about it and maybe someone knows how to help.
                                And next time don't forget to verify when you read the original dump.
                                  try this..
                                    I would like to remove bios pwd on my 840 g3 . It’s wson8 chip and have gold plated contacts near the bios chip (mx25L12873F).
                                    1/ Is ch341a programmer is compatible for dumping / writing the chip?
                                    2/ Is it possible to do that without desoldering the chip and solder wires directly on the contacts near it?
                                    Thanks for help
                                      Originally posted by tlfrance View Post
                                      I would like to remove bios pwd on my 840 g3 . It's wson8 chip and have gold plated contacts near the bios chip (mx25L12873F).
                                      Thanks for help
                                      Yes, try soldering wires. I always desolder wson8 chips but soldering wires to gold pads should work exactly like using a soic8 clip on soic8 chips. Don't forget to verify your dump.
                                        Thanks for help. I saw 2 different ch341a programmers (black pcb and green pcb) . Difference seems around voltage (5v for black , 3,3 v for green). Which one should I take?
                                          Hi everyone, i need help.
                                          I have a second-hand elitebook 850 g1 with bios locked by password.
                                          Understood that i need to unlock the BIOS is the ch431a programmer+soip8 with the software to dump my own bios file, to reprogram it and at last flash it. But i see on the motherboard two chips. Which is the correct one? I need to reprogram both bios?
                                          I've attached the img to be more clear.
                                          Thanks everyone
