you don't need to install this tool. just drag your file on this tool. its working on windows 10. or simple way:
1. put your locked bin file in HPunlocker folder.
2. open the folder (U will see 2 file, 1. your locked bin file 2. the tool it self)
3. drag your locked bin file on the tool
4. done u will get unlocked file
Well yes, that is a problem I don't know how to fix. I am not a software engineer so I just used the easiest methods I know by just turning a python file into an exe using auto-py-to-exe. There is no trojan involved. I have the same problem, bypassed it by adding that exe to exceptions in my anti-virus.
Thanks for trying to help @zmedia ,he made a thread 5 minutes before posting in this one for the same bios unlocking.If members can`t have any patience and keep double posting their threads will be removed.
Ok I understand, I did not pay attention to that, best regards
Hi First time doing this, I have a x360 Elitebook, I have a SOIC8 clip (purchased a kit from Ebay). I am trying to connect the SOIC 8 to the bios chip but the clips do not connect / reach to the flat gold plated / pins on the board.
Can anyone help how i can connect to the chip using the soic8? or is it a case for soldering to the board / remove the chip?
Edit - Just realished the bios type on the board is wson8..
Reason: chip type
I have a HP Elitebook 830 G5 and I don't have any access on :
1/ Windows 10
2/ Bios (locked with a password)
3/ Can't boot on USB
I just have the possibility to open cmd and have an access to my USB key. I downloaded the HPUnlocker program from Mazzif but I need the cmd one (not the windows one) Someone can upload it again for me ?
1/ Windows 10
Regards and thxs u,
Max
Mazzif tool cant unlock your system, u will need to remove the bios chip and program it with a new dump.. hope it helps
Thks for reply. Just need some help (if possible) with a good "how to". do you know a good one with a raspberry pi (using the gpio + a Test Clip SOIC8) ?
Just install raspbian on raspberry. Enable SPI in settings. Install newest flashrom. Most of the information you need is here: https://www.flashrom.org/RaspberryPi
