HP BIOS unlock tool
  • xerano
    • May 2019
    • 10
    • Deutschland
    #41
    Re: HP BIOS unlock tool
    All Done i love U everything works Like a Charm ♥️
    • Kamvret
      • Nov 2019
      • 6
      • Indonesia
      #42
      Originally posted by zmedia
      no i dont have spaces or other characters
      you don't need to install this tool. just drag your file on this tool. its working on windows 10. or simple way:
      1. put your locked bin file in HPunlocker folder.
      2. open the folder (U will see 2 file, 1. your locked bin file 2. the tool it self)
      3. drag your locked bin file on the tool
      4. done u will get unlocked file
      *I hope U understand how to drag file
      • new
        • Oct 2014
        • 157
        • canada
        #43
        Originally posted by RethoricalCheese
        Do you have spaces or other odd characters in file name or directory?
        HPUnlocker tool detected as Trojan.Win32.Blocker.tq1S mean it has a virus on it !! anyone can confirm ?
        • RethoricalCheese
          • Mar 2013
          • 1514
          • Estonia
          #44
          Well yes, that is a problem I don't know how to fix. I am not a software engineer so I just used the easiest methods I know by just turning a python file into an exe using auto-py-to-exe. There is no trojan involved. I have the same problem, bypassed it by adding that exe to exceptions in my anti-virus.
          The problem is known and brought up here: https://nitratine.net/blog/post/issu...exe-as-a-virus
          I might need to find another way to make executable files which have less problems.
          • chilugsm
            • Dec 2019
            • 4
            • Togo
            #45
            i have the same problem Failed to execute script HPUnlocker
            • 530v8
              • May 2019
              • 39
              Just drop you bin file to the exe file and it automatically creates another bin file on the folder where the bin file located
              • zmedia
                • May 2018
                • 62
                • Algerie
                #47
                I tryed to unlock this dump its not work someone can help thanks
                Last edited by SMDFlea; 12-28-2019, 07:08 AM. Reason: Already asked in another thread
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1173
                  • France
                  #48
                  try
                    • 20330
                    Originally posted by Maxpower3
                    try
                    Thanks for trying to help @zmedia ,he made a thread 5 minutes before posting in this one for the same bios unlocking.If members can`t have any patience and keep double posting their threads will be removed.
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1173
                      • France
                      #50
                      Ok I understand, I did not pay attention to that, best regards
                      • zmedia
                        • May 2018
                        • 62
                        • Algerie
                        #51
                        SORRY AND THANK U Maxpower3 MERCI
                        • e900
                          • Dec 2019
                          • 26
                          Hi First time doing this, I have a x360 Elitebook, I have a SOIC8 clip (purchased a kit from Ebay). I am trying to connect the SOIC 8 to the bios chip but the clips do not connect / reach to the flat gold plated / pins on the board.
                          Can anyone help how i can connect to the chip using the soic8? or is it a case for soldering to the board / remove the chip?
                          Edit - Just realished the bios type on the board is wson8..
                          • Zaraki7777
                            • Sep 2017
                            • 173
                            Thank you.
                            • RethoricalCheese
                              • Mar 2013
                              • 1514
                              • Estonia
                              #54
                              For wson8 you either need to unsolder chip and use the clip on chip only. Or solder wires to the gold pads.
                              • max67
                                • Jan 2020
                                • 5
                                • France
                                #55
                                I have a HP Elitebook 830 G5 and I don't have any access on :
                                1/ Windows 10
                                2/ Bios (locked with a password)
                                3/ Can't boot on USB
                                I just have the possibility to open cmd and have an access to my USB key. I downloaded the HPUnlocker program from Mazzif but I need the cmd one (not the windows one) Someone can upload it again for me ?
                                Regards and thxs u,
                                Max
                                • dammysholove
                                  • Jun 2017
                                  • 59
                                  • nigeria
                                  #56
                                  1/ Windows 10
                                  Regards and thxs u,
                                  Max
                                  Mazzif tool cant unlock your system, u will need to remove the bios chip and program it with a new dump.. hope it helps
                                  • max67
                                    • Jan 2020
                                    • 5
                                    • France
                                    #57
                                    Thks for reply. Just need some help (if possible) with a good "how to". do you know a good one with a raspberry pi (using the gpio + a Test Clip SOIC8) ?
                                    • max67
                                      • Jan 2020
                                      • 5
                                      • France
                                      #58
                                      or there is an easier way to dump it with Test Clip SOIC8 ?
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1514
                                        • Estonia
                                        #59
                                        At home I use a raspberry + soic8 clip.
                                        Just install raspbian on raspberry. Enable SPI in settings. Install newest flashrom. Most of the information you need is here: https://www.flashrom.org/RaspberryPi
                                        • max67
                                          • Jan 2020
                                          • 5
                                          • France
                                          #60
                                          ok, i just did it with a ch341a with the last version of flashrom, someone can unlock my .bin ? thks in advance
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
                                          • Kesavan
                                            HP 245 G10 BIOS UNLOCK FILE REQUEST
                                            by Kesavan
                                            Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                            Attached my backup file
                                            SERIAL NO: 5CG4300CNT...
                                            06-16-2025, 06:42 AM
                                          • Sebastian Codrean
                                            BIOS file for ASUS F542UN laptop
                                            by Sebastian Codrean
                                            Hello to all of you! I need help with a BIOS file.
                                            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                            02-20-2025, 10:25 AM
                                          • iZakre
                                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                            by iZakre
                                            Hello everybody!
                                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                            The thing is that I had installed TeamViewer and could log into the computer...
                                            02-19-2023, 02:27 PM
