T420s BIOS Request LSN-3 SWG
  • feherhollo
    • Nov 2019
    • 110
    • Hungary
    Can you please somebody post this bios or edit my current dump?
    I have faulty nvidia chip and need to select Intel HD in bios. Can somebody edit this setting and set Intel VGA for default??? If yes I will post my dump
  • feherhollo
    • Nov 2019
    • 110
    • Hungary
    Re: T420s BIOS Request LSN-3 SWG
    If somebody can edit my dump and able to set back to integrated graphics optimus disabled. Please let me know!! I upload my dump!!
    The problem is I have set to Discrete only optimus disabled. Now my laptop won't boot. Turn on but no display because faulty NVIDIA chip!
    • hoaca388
      Badcaps
      • Jan 2022
      • 11700
      What type of CPU do you have?
      • feherhollo
        • Nov 2019
        • 110
        • Hungary
        i7-2640M
        • hoaca388
          Badcaps
          • Jan 2022
          • 11700
          Originally posted by feherhollo
          i7-2640M
          upload your dump here
          • feherhollo
            • Nov 2019
            • 110
            • Hungary
            UPLOADED!!
            • hoaca388
              Badcaps
              • Jan 2022
              • 11700
              uploaded!!
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • hyperwood
                [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                by hyperwood
                I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                ✅ What I need:
                • A working 2MB BIOS dump
                • Matching NM-E471 Rev. 2.0, e.g. JY575
                06-25-2025, 02:28 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
