Predator PT315-52 Fh52m la-j891p
  • mazenkataya
    • Dec 2021
    • 45
    • lebanon
    Please help
    This laptop came from another repair shop it was no power after measurements the pch was the problem i replace pch ic and now the laptop came for life again but no display knowing that this was the main problem
    i attach the laptop bios file if any one can help
    my question is after pch need clear me or no
    laptop model predator triton 300
    SN:NHQ7AAA003033128323400
  • hoaca388
    Badcaps
    • Jan 2022
    • 12419
    Re: Fh52m la-j891p
    Originally posted by mazenkataya
    please help
    this laptop came from another repair shop it was no power after measurements the pch was the problem i replace pch ic and now the laptop came for life again but no display knowing that this was the main problem
    sn:nhq7aaa003033128323400
    Check your file with ME-Analyzer , it's show :
    • mazenkataya
      • Dec 2021
      • 45
      • lebanon
      Re: Fh52m la-j891p
      can you tell me where i can find bios chip on this mbo
      i have 2 bios chip and both when reading and check with me analyzer give erro
      the first one attach in the first post , the second one give me no intel engine firmware.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12419
        Re: Fh52m la-j891p
        Have you tried flashing the file I posted above?
        • mazenkataya
          • Dec 2021
          • 45
          • lebanon
          Re: Fh52m la-j891p
          no ,since it may be not the bios chip and maybe if i write bios file on it face another problem
          • hoaca388
            Badcaps
            • Jan 2022
            • 12419
            Re: Predator PT315-52 Fh52m la-j891p
            Look on both sides of the mainboard to see if there is a chip like Winbond 25Q128....Where did you get the file you posted in #1?
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Yep, that is good question.
              Become a Badcaps supporter
              Thanks to all supporters.
              • mazenkataya
                • Dec 2021
                • 45
                • lebanon
                from winbound chip but as i get is not bios file , i try to write bios file i get verification error at first adress
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12419
                  It is a bios file.
                    • 22107
                    Are using a CH341A programmer ? What part number is on the chip
                    • mazenkataya
                      • Dec 2021
                      • 45
                      • lebanon
                      YES I'M USING CH341A ,IT IS ATTACHED IN THE POST ABOVE
                      https://www.badcaps.net/forum/attach...hmentid=254804
                        • 22107
                        Try with different software https://www.badcaps.net/forum/showpo...81&postcount=8
                        • mazenkataya
                          • Dec 2021
                          • 45
                          • lebanon
                          i try all these softwares no luck, know laptop just light up power bo=utton and turn off, before it was working and fan spinning ,keybaord light up, know no life
                          • r-pass
                            • Apr 2021
                            • Czech Republic
                            Re: Fh52m la-j891p
                            But on this pictures is only 1MB size chip. Is not for BIOS!
                            There is another one, same side of motherboard, but near to hdmi, usb and usb-c connectors. Chip XMC QH128AHIG
                            • mazenkataya
                              • Dec 2021
                              • 45
                              • lebanon
                              Re: Fh52m la-j891p
                              yes you are right i also try but give error and reg 9 like this security
                              • astalavista00
                                • Feb 2021
                                • 9
                                • Uk
                                Hi can anyone help me make a new bios for the laptop acer predator pt315-52 rtx 2070 i7 10gen
                                motherboard is Fh52m la-j891p
                                Sn NHQ7AEK0010340D9C53400
                                • lapfix
                                  • Mar 2020
                                  • 2765
                                  • my workshop
                                  Tr and give feedback
                                  • scollinguk
                                    MTG Player
                                    • Dec 2023
                                    • 9
                                    Hi All,
                                    I am working on this laptop which came to me dead and not charging. I replaced two MOSFETs which now has the laptop charging and will turn on but it get no POST, just a blank screen when power is turned on (both on actual screen and HDMI).
                                    I expect the BIOS is corrupt. I have a CH314A which I am using. Strangely none of the programs can verify the BIOS once its been read. I've attached three dumps I got the chip, the first two were using SiberiaProg and the 3rd one is using ASProgrammer. Hoping that someone can help with creating a working BIOS for the laptop.
                                    Laptop serial number is NBQ7A11002033C34AD3400.
                                    I've read through the guide but havent been able to understand why the BIOS dumps cannot verify or what to do to correct? I've tried both ASProgrammer v2.04 and SiberiaProg v1.45.
                                    Thanks all!
                                    Scott
                                    Last edited by scollinguk; 12-28-2023, 11:38 AM. Reason: Forgot to attached the BIOS dumps...
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12419
                                      Originally posted by scollinguk
                                      Hi All,
                                      Thanks all!
                                      Scott
                                      Predator PT315-52 ( The bios3.rar file is dumped successfully )
                                      • Gcs_rma
                                        Banned
                                        • Dec 2023
                                        • 108
                                        • N/A
                                        PH315-52(INVENTEC)
