DAG31AMB6D0 rev D EC rom request
  • battery.12v
    • 123
    • NW
    found IO shorted to ground, replaced it, i need ec rom thx
    DAG31AMB6D0 rev D
  • peste
    • Dec 2016
    • 13920
    • ROMANIA
    Re: DAG31AMB6D0 rev D EC rom request
    DAG31AMB6D0 rev D
    post the full name and model of the laptop and the original Main bios.
    • battery.12v
      • 123
      • NW
      HP Pavilion 14-al028t DAG31AMB6D0 REV D
      i dont have the main EC bios Rom as THE old IO was dead, i changed it with a new IO, the new IO needs programming
      • peste
        • Dec 2016
        • 13920
        • ROMANIA
        I don't want the EC (I/O)chip bios, I want the 8MB main bios.
        • battery.12v
          • 123
          • NW
          this is a cleared bios
          • peste
            • Dec 2016
            • 13920
            • ROMANIA
            bios extracted from the HP site update, the laptop has three bios variants, yours is 08209
            DMI 6AC000 - 6AE0FF
            KEYWIN 278000 - 27803F
            • battery.12v
              • 123
              • NW
              thank you Sir working perfectly, can you tell me how you extracted EC bios from Bios update, what i know is that HP bios update have the Copy option but it will just extract Bios Files without EC
              • battery.12v
                • 123
                • NW
                i though it worked i was in a rush, unfortunately its giving me 5 long beeps and three short beeps for all three files
                • peste
                  • Dec 2016
                  • 13920
                  • ROMANIA
                  will only work with version 08209, write both bios (main and EC) ...
                  • battery.12v
                    • 123
                    • NW
                    i tried all three combination but no luck, this is my original bios the first one on the laptop before it went dead
                    • peste
                      • Dec 2016
                      • 13920
                      • ROMANIA
                      you said in post # 8 that it works with version 08209, the bios posted in post # 10 has version 08213 and corresponds to another motherboard model, so it can't work..you probably have another problem on the board ... change the bios chip for starters and rewrite
                      • jacospama
                        • Aug 2019
                        • 245
                        • Ghana
                        hp pavilion DAG31AMB6D0 REV D
                        how can i get I/O firmware for hp pavilion DAG31AMB6D0 REV D. and also i want to know when to flash I/O
                        • jacospama
                          • Aug 2019
                          • 245
                          • Ghana
                          Re: hp pavilion DAG31AMB6D0 REV D
                          this is my problem . if i plug the charger the jack led is on , but when i press the power buttun , it doesnt switch but the power jack blink when i press the swtch. thats was why i needed I/O.
                          • barry101
                            Apple 820-3662 VCore shorted to ground.
                            by barry101
                            Hi, Would appreciate some help.
                            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                            Get charger light but no fan spin or chime. No liquid damage.
                            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                            06-24-2025, 07:34 AM
                          • mkdj
                            Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
                            by mkdj
                            Dear all,
                            Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
                            I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
                            I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
                            08-11-2025, 04:55 AM
                          • L.L.
                            EXO UX133 the KBC has pin shorted to ground
                            by L.L.
                            Hi, on the UX133U motherboard (little info) the KBC (IT8987) has pin 59 shorted to ground, so there is a key always pressed.
                            Does anyone know if it can be cancelled by modifying the bios bin or reprogramming the KBC?
                            Thanks.​
                            03-05-2025, 10:46 AM
                          • AppleLover123
                            Acer Nitro 5 comes on then goes off
                            by AppleLover123
                            Hey guys,
                            i've got this laptop from a friend who gave it to me in a dead state.
                            The laptop wasn't working at all so i've began my search on the 19V power rail.
                            It was shorted to ground so i injected voltage and the only thing getting hot was my ground clip from my power supply.
                            I found that the +1.05V Rail for the Chipset was shorted. i removed the coil and it was shorted on the power delivery side.
                            The pch seems fine bc the rail has over 50 ohms after i removed the coil.
                            Still nothing was getting hot so i suggested the chip must...
                            10-09-2025, 04:51 PM
                          • im_trying
                            Dell Latitude 5310 2 in 1 Laptop does not power on, shorted capacitor replaced but not solved
                            by im_trying
                            Laptop does not power on but has a fix white light on power button, when connected to power.
                            I found, while trying to diagnose, a hot spot in the motherboard and found it to be a shorted capacitor (see photo below) on the 2.5v (2D5V_S3 on schematics). After replacing it with one from a donor board, still, the board does not turn on...
                            The usb-c meter reads upon connection 20.1v and 0.00a, with some occasional flashes to 0.03amps. After 10/15 seconds circa, it goes to 5.2v and draws an almost constant 0.07amps. (same behaviour as before)
                            To my fingers, nothing seems...
                            05-08-2025, 12:01 PM
