HP EliteBook x360 830 G6 [6050A3059101-MB-A01 A1]
  • Munuya
    • Nov 2020
    • 3
    • Kenya
    #61
    Originally posted by lapfix
    And what's your issue !!
    Post the laptop serial number
    I used one on the thread and it worked. thank you
    • winbond
      • Jul 2020
      • 56
      • uganda
      #62
      hello please remove for me endpoint security controller for hp EliteBook x360 830 g6 OR get me the script file compatible with this model.
      sn: 5CG0266vBV
        • 22279
        sn: 5CG0266vBV
        Do you mean the Tiny Hexer scripts ? - https://www.badcaps.net/forum/troubl...security-error
        The script will fail with the bios you posted as it has a double file name extension endpoint.bin.BIN ,it should be endpoint.bin
        Change the setting for Hide Extensions for Known File Types in explorer folder options, untick it ,apply/save. https://www.badcaps.net/filedata/fetch?id=2254691
        • winbond
          • Jul 2020
          • 56
          • uganda
          #64
          please help me patch it
            • 22279
            Have you tried it, did you rename the file endpoint.bin ,did you read the README.txt file included with the script ? ,i can`t make the instructions any easier ,where are you getting stuck ?
            • winbond
              • Jul 2020
              • 56
              • uganda
              #66
              thanks man , its okay now
              • dqtech
                Badcaps
                • Jul 2018
                • 641
                • N/A
                #67
                thanks
                • DUCKMAN
                  • Jan 2024
                  • 16
                  • VIETNAM
                  #68
                  could someone please unlock HP 830 G6
                  ProdID 7KJ5UT#ABA
                  SN# 5CG0152SVV
                • peste
                  • Dec 2016
                  • 13924
                  • ROMANIA
                  #69
                  ProdID 7KJ5UT#ABA
                  SN# 5CG0152SVV
                  try..if the password is not cleared, post the 16MB bios as well...
                  • DUCKMAN
                    • Jan 2024
                    • 16
                    • VIETNAM
                    #70
                    i loaded your file but it didnt work. the password may be in the 16mb file. please help me unlock it
                    • techrecycle
                      • Jan 2024
                      • 64
                      • england
                      #71
                      try this and update. thanks
                      • DUCKMAN
                        • Jan 2024
                        • 16
                        • VIETNAM
                        #72
                        works perfect , thanks man
                        • aldopc
                          • Jul 2017
                          • 484
                          • Chilito
                          #73
                          Hello friends, can someone please help me solve this problem? It gets stuck at 50%, restarts over and over again without making any progress.
                          Hp Elitebook X360 830 g6
                          Sn: 5CG9515MXF
                          • peste
                            • Dec 2016
                            • 13924
                            • ROMANIA
                            #74
                            Sn: 5CG9515MXF
                            Don't post pictures unless asked..
                            post the contents of the bios chip even if it is corrupted..
                            • aldopc
                              • Jul 2017
                              • 484
                              • Chilito
                              #75
                              ok bro
                              • aldopc
                                • Jul 2017
                                • 484
                                • Chilito
                                #76
                                Hi friends, could someone help? I've already tried cleaning the region, and it didn't work. I also cleaned the BIOS region, but without success...
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12441
                                  #77
                                  Try
                                  • aldopc
                                    • Jul 2017
                                    • 484
                                    • Chilito
                                    #78
                                    Originally posted by hoaca388
                                    Try
                                    Works perfectly, bro. You're a genius. Very grateful.
                                    • jackx
                                      • May 2020
                                      • 222
                                      • casa1
                                      #79
                                      can fix bios x360 g6
                                      6050A3059101-MB-A01
                                      2TK05000S3
                                      • rascao
                                        • Jul 2020
                                        • 53
                                        • España
                                        #80
                                        Hello i have a elitebook x360 830 g6 motherboard with the end point problem
                                        my board number is
                                        OKIWI-6050a3059101
                                        SN 5cg0132h0c
                                        8qj84ec#abd
                                        i try to use the patcher on the other post but when i patch my backup bios and install the bios IC the motherboard dont turn on, it just flash withe and orange light on the charger connector, this is my backup can anyone help? or point me on the right direction?
                                          SMDFlea commented
                                          Editing a comment
                                          moved from 840 g6 topic to 830 g6
                                        HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        09-06-2024, 08:27 AM
                                        HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-06-2024, 06:40 AM
                                        HP EliteBook x360 EliteBook x360 1020 G2 Notebook Specification for Upgrade or Repair
                                        This specification for the HP EliteBook x360 EliteBook x360 1020 G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1020 G2 boardview and EliteBook x360 1020 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-06-2024, 06:10 AM
                                        09-06-2024, 05:33 AM
