HP Spectre 360 13-w010nd corrupt bios file repair
  • Verlengsnoer
    • Sep 2016
    • 110
    • Netherlands
    hope this is the right topic,
    im looking to learn how to fix a corrupted laptop bios,
    and then im meaning when i backup the file, how to fix the currupted bios file, to fix the laptop without flashing 3rd party backups etc
    thanks in advance
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: corrupt bios file repair
    First , you need a device programmer to dump your bricked bios (this is the first required action) and flash new bios.
      • 22276
      thanks in advance
      What is the laptop make and model number.What is the laptop motherboard part number. Have you tried a bios recovery
      • Verlengsnoer
        • Sep 2016
        • 110
        • Netherlands
        hi, its a hp spectre 360 13 inch, for the mb no i need check, and recovery did not work.
        @hoaca388 i know and i allready took a backup/dump of the corrupted bios
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Post your dump file bios here.
          • Verlengsnoer
            • Sep 2016
            • 110
            • Netherlands
            here u go
              • 22276
              here u go
              What you`ve posted is a virgin bios.Is that the original bios backup .What is the laptop serial number, and the full laptop model number.
              • Verlengsnoer
                • Sep 2016
                • 110
                • Netherlands
                hi, yes its the original backup
                its a HP Spectre 360 13-w010nd and the serial nr is: 5CD7035NHQ
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  its a hp spectre 360 13-w010nd and the serial nr is: 5cd7035nhq
                  • Verlengsnoer
                    • Sep 2016
                    • 110
                    • Netherlands
                    thanks, will give it a try
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • maanee11
                      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                      by maanee11
                      Hello Everyone,
                      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                      In the website, you can only see specs etc.
                      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                      11-08-2025, 04:08 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      Hi everyone
                      09-06-2025, 05:47 PM
                    • rickjansen01
                      Asus FA707 corrupt Bios File
                      by rickjansen01
                      Hello Guy's
                      Can somebody help me whit this problem
                      Asus FA707 bios file is corrupt
                      sn T3NRCXCZR00Y117
                      original file uploaded
                      Regards chris...
                      04-20-2025, 07:12 AM
                    • Forest79
                      by Forest79
                      07-23-2023, 07:39 AM
