AMITSESetup Decryptor
hoaca388 is right, the best and (almost) 100% safe method to remove the password is to read the BIOS with a programmer (twice is better and compare the readings to be sure they are the same).
In your case I try to remove the password from the dump you have provided. Try to write it and check for the Admin password if it's been removed. Provide feedback.
the screen in the image below showed up after i installed the patched version you provided using this command line:
.\AFUWINx64.exe G712LWS_patched.rom RECOVERY /B /N REBOOT
and it retained for like 2 to 3 minutes and then the device booted by itself to windows, but the password still exist.
also the AFUWIN GUI kept giving me errors, so i used the terminal instead, errors like 18 and 32, (unable to read sectors or something)Attached Filesif you find these attachements useful please consider making a small donation to the site
...and did you try the presented recovery method ?
I downloaded your recovery file, so copy it to the root of a USB stick and reboot your laptop.
At least we try to unlock your device. If you will manage to read the BIOS flash with a programmer then are more chances to reset your forgotten password...Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes, I tried it multiple times with different USB formats (NTFS and FAT32), but nothing happened. The same screen showed up until it disappeared, and the computer booted back to Windows again.
If I buy a programmer, will I inadvertently harm my device, or does it handle errors safely? Like, can it read the actual password without replacing the firmware, or will I have to modify it?
(I watched some YouTube videos about the flasher "ch341a", but I found it hard to understand)Comment
Did you rename your file on the FAT32 formatted USB stick to G712LWS.BIN ? If not, rename it and try again...
It's possible to plug the usb to your laptop. turn on laptop and quickly press CTRL+HOME and wait... it should boot to EZflash bios and reupdate it.
Try with an older version...rename the bios file to .BIN - put in the root of USB stick - press-power on - then press CTRL+HOME.Attached Filesif you find these attachements useful please consider making a small donation to the site
It doesn't even want to boot anymore, is it dead?
I'm freaking terrified right now. 🙁Comment
Take out your battery and your power adapter and do a CMOS reset by holding power on button for at least 30 seconds.
...or take out the CMOS battery after removing the back cover and reinsert it after 30 seconds.
The USB restore method worked fine on another ASUS models...it's the same on Rog.
So after all it seems you get to read your BIOS with a programmer.
See here: https://www.youtube.com/watch?v=DWWigscuQDYComment
It didn't work for me, i tried all possible solutions, (Ctrl + Home) and (Fn + Esc), also tried to discharge it (for 30s and more), and nothing happens, i guess ill go buy a programmer or taking it to a repair service, I'll type a feedback about what happens later.
I bought an SPI programmer (CH341A), and below is the backup file I got from the BIOS (Yes, I watched many videos, and checked that the tool is connected correctly and can detect the BIOS and all backup file's md5 value was the same).
I tried to write the Asus manufacturer file to the BIOS but I got this error:
AsProgrammer v2.1.2
https://github.com/nofeletru/UsbAsp-flash
Current programmer: CH341
ID(9F): EF6014
ID(90): EF13
ID(AB): 13
ID(15): 0000
8:04:57 PM
Reading memory...
Done
Execution time: 12:00:09 AM
CRC32 = 0xB1397417
Old SREG: 00000000(0x00)
New SREG: 00000000(0x00)
8:05:30 PM
Erasing memory...
The process can take more than a minute on large flash!
Done
Execution time: 12:00:00 AM
8:05:31 PM
File size larger than IC size
I don't get it, how could 16mb BIOS file turn into 1mb BIOS file??
One more thing, after I tried to write that original BIOS file into the BIOS, there are no backup files that their md5 equal to each other anymore. So, luckily I am I made a backup file once it was connected to the PC I'm working on right now, I guess?
EDIT:
If I tried to write the backup file back to the BIOS, I get the following error:
8:18:00 PM
Programming memory (with verification)...
Verification error on address: 00000000
You have read the wrong chip...look for a MX25L12873F I think (U2802???)...a 16MB (128Mb) chip and read that one.
AsProgrammer v2.1.2
ID(9F): EF6014
ID(90): EF13
ID(AB): 13
ID(15): 0000
8:04:57 PM
Reading memory...
Done
CRC32 = 0xB1397417
8:05:30 PM
Erasing memory...
Done
8:05:31 PM
EDIT:
8:18:00 PM
I don't remember that you have posted your serial number , please provide the serial of your laptop.Last edited by Stefan Steff; 06-10-2025, 01:31 PM.Comment
G712LWS-EV002-Gaming
SN: L7NRKD031177304
CN: 778L
MFD: 2020-07
Thank you bro you take from your time helping me. 🙏🏻Comment
isnt it this chip?
there isn't any other chip on the motherboard that the clip can stick on except this one in the image, also the programmer detected it automatically.
WINBOND 25Q80EWNI15 2015Attached Filesif you find these attachements useful please consider making a small donation to the site
No, No...must be something like 25Q128JV or FV...anyway '128' must be in the name of the chip.
Look on the other side too
is it this one?
and another question, if the flashing succeeded, after turning on the device, will the other chip recover its code? because its erased automatically when i tried to write that BIOS file into it.
EDIT:
I have 3 valid backups with the same md5 value that I extracted from the chip "WINBOND 25Q80EWNI15 2015" today, but the chip doesn't accept to flash any of them.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last update:
is it this one?
EDIT:
After I have made tens of researches,
1: I figured out that the WINBOND chip needs an adapter (1.8v) plugged into the ch341a programmer to be able to write on it without problems (luckily I'm it is not broken because of the many times i tried to write back the backup images into it).
2: Later I decided to connect the bios into the flasher, and i took many backups (see the attachment file), they were all with the same md5 value.
Problems I faced:
- Firstly, the flasher couldn't read the real name of the bios chip, but a one the is really close to it, and from the internet, some people faced the same problem and flashed on the different bios name and the claim that they succeeded.
- - I found the reason that was causing this problem and how to fix it.... It was the USB port of the laptop that i plugged the flasher into it, and I fixed it by connecting into a hub that uses its own power supply charger (Ugreen hub 7 ports), and then plugged the hub into laptop's USB port and (NeoProgrammer) was able to get the exact name of the BIOS. OR the clip might not be plugged correctly on the chip, so make sure you try many times before you decide to plug the flasher into, i.e. a usb hub or external power source ==> BTW, this tip was from ChatGPT o4-mini-high
- I also learned that before you try to write any rom/bin/firmware image, you have to click on READ and then VERIFY to make sure that the flasher you use will not fail while its trying to inject/install the firmware image, so you know that you are using the right adaptor or working flasher (not broken).
- from some videos i watched, modifying the flasher may lead to install modified firmware images that gets modified during the installation process. (so don't modify the flasher you bought, just make sure that you are using the right adaptor for the chip you want to flash, and connect it to the adaptor, and connect/plugin the adaptor into the flasher). ==> here I'm talking about CH341A Black flasher cases.
- I need someone to that know how to modify the manufacturer bios file so it's size become equal to one of the backup files' size. I'll be very thankful for who can help me doing this, as I don't know how to do it.
Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
This is your rebuilded bios.
Last update:
Problems I faced:
Thanks in advance.
Provide feedback .Attached Filesif you find these attachements useful please consider making a small donation to the site
- Flash => Complete
- Verification = Complete
- Read & Verify after flash => Complete
- Verify flashed backups' md5 value => complete => 3 backups with the same md5 value
Before installing:
C:\Users\HP\Downloads\BIOS>certutil -hashfile New_BIOS.bin md5
MD5 hash of New_BIOS.bin:
1af147638b8bb5a3309729288a743e69
CertUtil: -hashfile command completed successfully.
After installing:
C:\Users\HP\Downloads\BIOS>certutil -hashfile New_BIOS_backup.bin md5
MD5 hash of New_BIOS_backup.bin:
The result after turning on the device will have to be delayed for a few hours until the morning comes and i go buy an adapter for the flasher to burn one of the backup files to the other chip that i erased yesterday.
Thanks for taking from your time to help me. I also hope that you could rebuilding the firmware image correctly from the first time.Comment
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-06-2024, 10:56 AM
This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...09-06-2024, 10:56 AM
- Loading...
