AMITSESetup Decryptor
  • axeba
    • Feb 2025
    • 4
    • Italia
    #161
    Thanks you so much! and sorry for english (translate), Saved this computer from trash !!!!
    • Chipsi
      • Jun 2018
      • 3
      • Finland
      #162
      Tried this but didn't succeed to find password, any ideas?
      Machine is Asus GL10CS-NR113T
      SN: K7PDCG001024270​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12044
        #163
        SN: K7PDCG001024270​[
        • Gspot
          • Mar 2025
          Please I ned help to decrypt password or else just to unlock. thank you
          Panasonic / Toughbook CF-195MAC3CA
          SN:4KKSA05211
          Motherboad: DFU2123ZB
          • hoaca388
            Badcaps
            • Jan 2022
            • 12044
            #165
            SN:4KKSA05211
            • Bozog
              • Jan 2022
              • 125
              Hi, can someone help unlock this file, I tried zeroing out the password in 2 locations but it didn't seem to work - just black screen, what am I missing?
              Toughbook CF-20GV-52TE
              Serial 2EKCD30382
              • Bozog
                • Jan 2022
                • 125
                Serial 2EKCD30382
                Don't worry, I fixed it - one of the tiny resistors had broken.
                Now the BIOS is unlocked the HDD doesn't seem to work anymore, aaargh
                • stevebeef
                  • Mar 2025
                  • 9
                  • germany
                  #168
                  this is what i get?​
                  • Gspot
                    • Mar 2025
                    Sorry for late reply ..!
                    With my trial and error, I manage to get it worked. and just comparing the bin file I got the same result as you do
                    so from this I have learned something new
                    And thanks for your response knowing i'm in the right paths
                    • Areos
                      • Jun 2020
                      • 35
                      • México
                      #170
                      Thank you!! works great for vivobook E1504F.
                      • My3Rckio
                        • Apr 2025
                        • 6
                        • Italy
                        #171
                        Hi, I have an Asus E510MA with an administrator password in the BIOS that I don't know and I can't find a way to delete it. The Alt+R method doesn't work, the Decryptor doesn't find anything and with the Freeware Hex Editor software the probable password is not decoded from the site https://www.rapidtables.com. I also managed to update the BIOS but the password remained. What should I do? Thanks​
                          SMDFlea commented
                          Editing a comment
                          post your backup ,and laptop serial number.
                      • My3Rckio
                        • Apr 2025
                        • 6
                        • Italy
                        #172
                        The serial number is:
                        MANOCX27H786434​
                        • Bios Cracker
                          • Oct 2024
                          • 318
                          • India
                          #173
                          MANOCX27H786434​
                          Try and Update.
                          • My3Rckio
                            • Apr 2025
                            • 6
                            • Italy
                            #174
                            The WinFlash software does not let me update the BIOS because it tells me that "it is previous to the current version"!!! 😫😥
                            • My3Rckio
                              • Apr 2025
                              • 6
                              • Italy
                              #175
                              I tried with the command "/nodate" from cmd and the software starts but in this case it tells me that the BIOS file is not valid....
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12044
                                #176
                                Use this
Name:	2025-04-20 09_46_10-.png
                                https://www.youtube.com/results?sear...mer+how+to+use
                                • My3Rckio
                                  • Apr 2025
                                  • 6
                                  • Italy
                                  #177
                                  Is it not possible to decrypt the password from the bios backup I sent you? If via software it tells me that the bios you corrected is not valid, what happens if I flash it forcibly with a programmer? And in any case, since I had updated the bios to the latest version but the password remained, could it be that this is saved on another chip?
                                  • Stefan Steff
                                    • Mar 2024
                                    • 304
                                    • Romania
                                    #178
                                    I can't decrypt your password but I can remove it if it's ok...
                                    • My3Rckio
                                      • Apr 2025
                                      • 6
                                      • Italy
                                      #179
                                      Unfortunately it tells me that the BIOS file is not valid like the other one that had been kindly unlocked for me. I don't understand why this happens. If I were to forcibly flash this unlocked BIOS I fear that I could completely brick the notebook
                                        • 21394
                                        Buy an SPI programmer.
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
