AMITSESetup Decryptor
    Thanks you so much! and sorry for english (translate), Saved this computer from trash !!!!
      Tried this but didn't succeed to find password, any ideas?
      Machine is Asus GL10CS-NR113T
      SN: K7PDCG001024270
        SN: K7PDCG001024270
        SN: K7PDCG001024270[
        Become a Badcaps supporter
        Thanks to all supporters.
          Please I ned help to decrypt password or else just to unlock. thank you
          Panasonic / Toughbook CF-195MAC3CA
          SN:4KKSA05211
          Motherboad: DFU2123ZB
            SN:4KKSA05211
              Hi, can someone help unlock this file, I tried zeroing out the password in 2 locations but it didn't seem to work - just black screen, what am I missing?
              Toughbook CF-20GV-52TE
              Serial 2EKCD30382
                Serial 2EKCD30382
                Don't worry, I fixed it - one of the tiny resistors had broken.
                Now the BIOS is unlocked the HDD doesn't seem to work anymore, aaargh
                  this is what i get?
                    Sorry for late reply ..!
                    With my trial and error, I manage to get it worked. and just comparing the bin file I got the same result as you do
                    so from this I have learned something new
                    And thanks for your response knowing i'm in the right paths
                      Thank you!! works great for vivobook E1504F.
                        Hi, I have an Asus E510MA with an administrator password in the BIOS that I don't know and I can't find a way to delete it. The Alt+R method doesn't work, the Decryptor doesn't find anything and with the Freeware Hex Editor software the probable password is not decoded from the site https://www.rapidtables.com. I also managed to update the BIOS but the password remained. What should I do? Thanks
                          SMDFlea commented
                          Editing a comment
                          post your backup ,and laptop serial number.
                        The serial number is:
                        MANOCX27H786434
                          MANOCX27H786434
                          Try and Update.
                            The WinFlash software does not let me update the BIOS because it tells me that "it is previous to the current version"!!! 😫😥
                              I tried with the command "/nodate" from cmd and the software starts but in this case it tells me that the BIOS file is not valid....
                                Use this
Name:	2025-04-20 09_46_10-.png
                                https://www.youtube.com/results?sear...mer+how+to+use
                                  Is it not possible to decrypt the password from the bios backup I sent you? If via software it tells me that the bios you corrected is not valid, what happens if I flash it forcibly with a programmer? And in any case, since I had updated the bios to the latest version but the password remained, could it be that this is saved on another chip?
                                    I can't decrypt your password but I can remove it if it's ok...
                                      Unfortunately it tells me that the BIOS file is not valid like the other one that had been kindly unlocked for me. I don't understand why this happens. If I were to forcibly flash this unlocked BIOS I fear that I could completely brick the notebook
                                        Buy an SPI programmer.
