AMITSESetup Decryptor
  • Stefan Steff
    • Mar 2024
    • 357
    #201
    Originally posted by TraJikar Mac
    Isn't there any other solution? (this is not my area of expertise), I am afraid of breaking my laptop, as I need to remove the administrator password so I can enable virtual technology or something similar.
    I set the password 2 or 3 years ago and forgot it; since then, I have been trying to remember it or crack it.
    The script "AMITSEDecrypt.py" script gave me a wrong password: "hƸG2f".
    I also have a question: Is the BIOS password case-sensitive, or are all letters automatically converted to lowercase/uppercase?
    I just give you the other solution...and yes the BIOS passwords are case sensitive.
    • TraJikar Mac
      • Jun 2025
      • 28
      • Turkey
      #202
      Originally posted by Stefan Steff
      hoaca388 is right, the best and (almost) 100% safe method to remove the password is to read the BIOS with a programmer (twice is better and compare the readings to be sure they are the same).
      In your case I try to remove the password from the dump you have provided. Try to write it and check for the Admin password if it's been removed. Provide feedback.
      the screen in the image below showed up after i installed the patched version you provided using this command line:
      .\AFUWINx64.exe G712LWS_patched.rom RECOVERY /B /N REBOOT
      and it retained for like 2 to 3 minutes and then the device booted by itself to windows, but the password still exist.
      also the AFUWIN GUI kept giving me errors, so i used the terminal instead, errors like 18 and 32, (unable to read sectors or something)
      • Stefan Steff
        • Mar 2024
        • 357
        #203
        ...and did you try the presented recovery method ?
        I downloaded your recovery file, so copy it to the root of a USB stick and reboot your laptop.
        At least we try to unlock your device. If you will manage to read the BIOS flash with a programmer then are more chances to reset your forgotten password...
        • TraJikar Mac
          • Jun 2025
          • 28
          • Turkey
          #204
          Yes, I tried it multiple times with different USB formats (NTFS and FAT32), but nothing happened. The same screen showed up until it disappeared, and the computer booted back to Windows again.
          If I buy a programmer, will I inadvertently harm my device, or does it handle errors safely? Like, can it read the actual password without replacing the firmware, or will I have to modify it?
          (I watched some YouTube videos about the flasher "ch341a", but I found it hard to understand)
          • Stefan Steff
            • Mar 2024
            • 357
            #205
            Did you rename your file on the FAT32 formatted USB stick to G712LWS.BIN ? If not, rename it and try again...
            It's possible to plug the usb to your laptop. turn on laptop and quickly press CTRL+HOME and wait... it should boot to EZflash bios and reupdate it.
            Try with an older version...rename the bios file to .BIN - put in the root of USB stick - press-power on - then press CTRL+HOME.
            • TraJikar Mac
              • Jun 2025
              • 28
              • Turkey
              #206
              It doesn't even want to boot anymore, is it dead?
              I'm freaking terrified right now. 🙁
              • TraJikar Mac
                • Jun 2025
                • 28
                • Turkey
                #207
                It somehow turned on, but only the keyboard lights, and then nothing happens. It doesn't boot neither to BIOS nor to windows nor to USB.
                Just nothing.
                • Stefan Steff
                  • Mar 2024
                  • 357
                  #208
                  Just nothing.
                  Take out your battery and your power adapter and do a CMOS reset by holding power on button for at least 30 seconds.
                  ...or take out the CMOS battery after removing the back cover and reinsert it after 30 seconds.
                  The USB restore method worked fine on another ASUS models...it's the same on Rog.
                  So after all it seems you get to read your BIOS with a programmer.
                  See here: https://www.youtube.com/watch?v=DWWigscuQDY
                  • Holaa321
                    • Jun 2023
                    • 10
                    #209
                    Originally posted by hoaca388
                    Here
                    Thank you after flashing it worked like a charm. Many thanks.
                    • TraJikar Mac
                      • Jun 2025
                      • 28
                      • Turkey
                      #210
                      It didn't work for me, i tried all possible solutions, (Ctrl + Home) and (Fn + Esc), also tried to discharge it (for 30s and more), and nothing happens, i guess ill go buy a programmer or taking it to a repair service, I'll type a feedback about what happens later.
                      • TraJikar Mac
                        • Jun 2025
                        • 28
                        • Turkey
                        #211
                        I bought an SPI programmer (CH341A), and below is the backup file I got from the BIOS (Yes, I watched many videos, and checked that the tool is connected correctly and can detect the BIOS and all backup file's md5 value was the same).
                        I tried to write the Asus manufacturer file to the BIOS but I got this error:
                        AsProgrammer v2.1.2
                        https://github.com/nofeletru/UsbAsp-flash
                        Current programmer: CH341
                        ID(9F): EF6014
                        ID(90): EF13
                        ID(AB): 13
                        ID(15): 0000
                        8:04:57 PM
                        Reading memory...
                        Done
                        Execution time: 12:00:09 AM
                        CRC32 = 0xB1397417
                        Old SREG: 00000000(0x00)
                        New SREG: 00000000(0x00)
                        8:05:30 PM
                        Erasing memory...
                        The process can take more than a minute on large flash!
                        Done
                        Execution time: 12:00:00 AM
                        8:05:31 PM
                        File size larger than IC size
                        I don't get it, how could 16mb BIOS file turn into 1mb BIOS file??
                        One more thing, after I tried to write that original BIOS file into the BIOS, there are no backup files that their md5 equal to each other anymore. So, luckily I am I made a backup file once it was connected to the PC I'm working on right now, I guess?
                        EDIT:
                        If I tried to write the backup file back to the BIOS, I get the following error:
                        8:18:00 PM
                        Programming memory (with verification)...
                        Verification error on address: 00000000
                        • Stefan Steff
                          • Mar 2024
                          • 357
                          #212
                          AsProgrammer v2.1.2
                          ID(9F): EF6014
                          ID(90): EF13
                          ID(AB): 13
                          ID(15): 0000
                          8:04:57 PM
                          Reading memory...
                          Done
                          CRC32 = 0xB1397417
                          8:05:30 PM
                          Erasing memory...
                          Done
                          8:05:31 PM
                          EDIT:
                          8:18:00 PM
                          You have read the wrong chip...look for a MX25L12873F I think (U2802???)...a 16MB (128Mb) chip and read that one.
                          I don't remember that you have posted your serial number , please provide the serial of your laptop.
                          • TraJikar Mac
                            • Jun 2025
                            • 28
                            • Turkey
                            #213
                            G712LWS-EV002-Gaming
                            SN: L7NRKD031177304
                            CN: 778L
                            MFD: 2020-07
                            Thank you bro you take from your time helping me. 🙏🏻
                            • Stefan Steff
                              • Mar 2024
                              • 357
                              #214
                              SN: L7NRKD031177304
                              CN: 778L
                              MFD: 2020-07
                              Of course...we make it work again (I hope if I can't somebody smarter will help you out...)
                              • TraJikar Mac
                                • Jun 2025
                                • 28
                                • Turkey
                                #215
                                isnt it this chip?
                                there isn't any other chip on the motherboard that the clip can stick on except this one in the image, also the programmer detected it automatically.
                                WINBOND 25Q80EWNI15 2015
                                • Stefan Steff
                                  • Mar 2024
                                  • 357
                                  #216
                                  isnt it this chip?
                                  No, No...must be something like 25Q128JV or FV...anyway '128' must be in the name of the chip.
                                  Look on the other side too
                                  • TraJikar Mac
                                    • Jun 2025
                                    • 28
                                    • Turkey
                                    #217
                                    is it this one?
                                    and another question, if the flashing succeeded, after turning on the device, will the other chip recover its code? because its erased automatically when i tried to write that BIOS file into it.
                                    EDIT:
                                    I have 3 valid backups with the same md5 value that I extracted from the chip "WINBOND 25Q80EWNI15 2015" today, but the chip doesn't accept to flash any of them.
                                    • TraJikar Mac
                                      • Jun 2025
                                      • 28
                                      • Turkey
                                      #218
                                      is it this one?
                                      EDIT:
                                      Last update:
                                      After I have made tens of researches,
                                      1: I figured out that the WINBOND chip needs an adapter (1.8v) plugged into the ch341a programmer to be able to write on it without problems (luckily I'm it is not broken because of the many times i tried to write back the backup images into it).
                                      2: Later I decided to connect the bios into the flasher, and i took many backups (see the attachment file), they were all with the same md5 value.
                                      Problems I faced:
                                      - Firstly, the flasher couldn't read the real name of the bios chip, but a one the is really close to it, and from the internet, some people faced the same problem and flashed on the different bios name and the claim that they succeeded.
                                      - - I found the reason that was causing this problem and how to fix it.... It was the USB port of the laptop that i plugged the flasher into it, and I fixed it by connecting into a hub that uses its own power supply charger (Ugreen hub 7 ports), and then plugged the hub into laptop's USB port and (NeoProgrammer) was able to get the exact name of the BIOS. OR the clip might not be plugged correctly on the chip, so make sure you try many times before you decide to plug the flasher into, i.e. a usb hub or external power source ==> BTW, this tip was from ChatGPT o4-mini-high
                                      - I also learned that before you try to write any rom/bin/firmware image, you have to click on READ and then VERIFY to make sure that the flasher you use will not fail while its trying to inject/install the firmware image, so you know that you are using the right adaptor or working flasher (not broken).
                                      - from some videos i watched, modifying the flasher may lead to install modified firmware images that gets modified during the installation process. (so don't modify the flasher you bought, just make sure that you are using the right adaptor for the chip you want to flash, and connect it to the adaptor, and connect/plugin the adaptor into the flasher). ==> here I'm talking about CH341A Black flasher cases.
                                      - I need someone to that know how to modify the manufacturer bios file so it's size become equal to one of the backup files' size. I'll be very thankful for who can help me doing this, as I don't know how to do it.
                                      Thanks in advance.
                                      • Stefan Steff
                                        • Mar 2024
                                        • 357
                                        #219
                                        Last update:
                                        Problems I faced:
                                        Thanks in advance.
                                        This is your rebuilded bios.
                                        Provide feedback .
                                        • TraJikar Mac
                                          • Jun 2025
                                          • 28
                                          • Turkey
                                          #220
                                          Provide feedback .
                                          - Flash => Complete
                                          - Verification = Complete
                                          - Read & Verify after flash => Complete
                                          - Verify flashed backups' md5 value => complete => 3 backups with the same md5 value
                                          Before installing:
                                          C:\Users\HP\Downloads\BIOS>certutil -hashfile New_BIOS.bin md5
                                          MD5 hash of New_BIOS.bin:
                                          1af147638b8bb5a3309729288a743e69
                                          CertUtil: -hashfile command completed successfully.
                                          After installing:
                                          C:\Users\HP\Downloads\BIOS>certutil -hashfile New_BIOS_backup.bin md5
                                          MD5 hash of New_BIOS_backup.bin:
                                          The result after turning on the device will have to be delayed for a few hours until the morning comes and i go buy an adapter for the flasher to burn one of the backup files to the other chip that i erased yesterday.
                                          Thanks for taking from your time to help me. I also hope that you could rebuilding the firmware image correctly from the first time.
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            08-18-2025, 11:38 AM
                                            HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            09-06-2024, 10:56 AM
                                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
