dell xps 13 9300 fdq30 la-h811p rev:1.0 bios
  • stars-n-dust
    • Apr 2019
    • 59
    Re: dell xps 13 9300 fdq30 la-h811p rev:1.0 bios
    Here's your New BIOS, try it and let me know.
    Not working. Fans spinning, stuck on Dell logo.
    • PitMakot
      • Mar 2018
      • 12
      • Poland
      #42
      Originally posted by Qbinhelec
      UC23 fail, 1v8 falled 0.5V.
      1.1V_MEM_EN =0.5V
      +1.1V_MEMP falled 0.5V
      This is the problem of a defective CPU and connections between motherboard and CPU.
      You have to replace CPU.
      • stars-n-dust
        • Apr 2019
        • 59
        The CPU is ok, same as everything else. All working with the original BIOS chip. Like mentioned in post #34, there is a corporate password that's needed to be cleared.
        • trepachka
          • Oct 2022
          • 447
          Ok, I had some time today and I had the motherboard removed. Looks like there are 2 25Q80DVIG chips on each side of the motherboard close to USB-C ports. Otherwise, I am at a loss here. Can someone point out where the BIOS chip location is?
          • trepachka
            • Oct 2022
            • 447
            Never mind, I was able to locate the BIOS chip. It is DG25B256DY1G.
            • trepachka
              • Oct 2022
              • 447
              XPS 9300 shows Dell logo, keyboard lights up, then computer reboots and cycle repeats. Looks like BIOS is corrupted. Current BIOS dump is attached. Could someone, please clean the BIOS file? Thank you.
              Service Tag# 7M18X33
              • PitMakot
                • Mar 2018
                • 12
                • Poland
                #47
                • trepachka
                  • Oct 2022
                  • 447
                  I would like to try to reflash the BIOS but I need someone help me rebuild. I would really appreciate this.
                  • hardware1
                    • Sep 2021
                    • 2946
                    • N/A
                    #49
                    all donations are welcome,
                    • trepachka
                      • Oct 2022
                      • 447
                      I applied the new BIOS and only keyboard lights up. When pressing power button, charging light array upfront flashes amber color.
                      • trepachka
                        • Oct 2022
                        • 447
                        Hey hardware1, this bios didn't work for me.
                        • hardware1
                          • Sep 2021
                          • 2946
                          • N/A
                          #52
                          Sorry but I don't have another option. You can find any dump file and try it then see if it will works or not.
                          • PitMakot
                            • Mar 2018
                            • 12
                            • Poland
                            #53
                            BIOS does not work because it is not a bios defect.
                            Apply the original BIOS and heat the APU to about 80 degrees.
                            Start a hot laptop. He should start correctly.
                            This will confirm the APU fault.
                            • ahmedelwn
                              • Oct 2022
                              • 27
                              • egypt
                              #54
                              Stop at the word deLL
                              please help
                              • Markus1741
                                • Sep 2020
                                • 922
                                • N/A
                                #55
                                please help
                                Try ...
                                • quepaso
                                  • Mar 2020
                                  • 10
                                  • Russia
                                  #56
                                  Hello, there are flash memory dumps of controllers Type C? numbers on the board UPD3 and UPD4
                                  • quepaso
                                    • Mar 2020
                                    • 10
                                    • Russia
                                    #57
                                    TPS65987D flash 25Q80DV
                                      • 21679
                                      Have you checked for the firmware updates at dell support.If there are some they will need extracting form the downloads and possibly trimming to the correct size with a hex editor ?, not sure.
                                      • quepaso
                                        • Mar 2020
                                        • 10
                                        • Russia
                                        #59
                                        the laptop does not turn on, the TPS65987D flash memory is not working properly, a dump is needed
                                        • jacobk1508
                                          • May 2016
                                          • 69
                                          • Viet Nam
                                          #60
                                          Hi everybody. Is there a solution to the poster's problem yet? I'm also facing the same situation.
                                            DELL XPS 9300-6892 Ultraportable 13 Specification for Upgrade or Repair
                                            This specification for the DELL XPS 9300-6892 Ultraportable can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9300-6892 boardview and 9300-6892 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-06-2024, 06:50 PM
                                            DELL XPS 9300 Ultraportable 13 Specification for Upgrade or Repair
                                            This specification for the DELL XPS 9300 Ultraportable can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9300 boardview and 9300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9300 Ultraportable...
                                            09-06-2024, 06:00 PM
