Thank You,
Keeps restarting but w/o image...1 min ON then 2-3 seconds OFF and again...
Both chips were written.
HP Elitebook 850 G6 BIOS UNLOCK
Thank You!
Laptop started OK with this dump.
Pressed F10 -> Factory Defaults -> 2nd start - Security defaults then inserted DMI info.
After that the late start comes back
Again took 15 seconds to start up but additionally I got on error about ME corrupted....
Thanks again for your time.
S.S.Attached FilesLeave a comment:
Thank You!
S.S.Leave a comment:
first boot press f10 reset bios to factory defaults (restart) 2nd boot reset security settings to defaults.
Use BCU to fill these DMI info:
Serial Number: 5CG0100M36
Product #/SKU: 4YD58AV
CT Number: PHWGR00WBDF003
Description: HP EliteBook 850 G6
BuildID: 19WWCFBT601#SABH#DABH
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPfXhKhkjhk8.T7Attached FilesLeave a comment:
Hi!
Laptop : EliteBook 850 G6
SN : 5CG0100M36
Stuck in boot loop after cleaning ME (restarts in 2-3 seconds after logo appears)
Took 15-20 seconds to boot before cleaning ME.
If somebody take a look what's wrong with this file...
Thank you!Attached FilesLeave a comment:
Thread merged.
Please use the forum search to find related threads where you can post your request. You're NOT allowed to start a new thread if there's an existing one!!!
https://www.badcaps.net/forum/troubl...before-posting -
Thank you very much. Laptop runs without any issues after additional security settings reset in bios (FP error code 10). Have a nice day/night.Leave a comment:
Serial Number: 5CG9527NJM
Product Number: 4YD61AV
CT Number: PHWHB00WBD6885
build_id: 19WWCFBT601#SUUG#DUUG
MAC Address: E8-D8-D1-E9-58-04Attached FilesLeave a comment:
I'm trying to repair HP Elitebook 850 G6 with damaged and unreadable EC 16MB chip. I've replaced it with exactly the same chip from donor motherboard and flashed it with couple firmwares. Laptop is waking up every time and it seems that it's working properly but I'm getting "HP Endpoint Security controller problem" at boot. I've tried couple EC firmwares from this forum but this problem persists and I cannot find any way to fix it.
Is there any way to recreate EC bios from scratch or extract if from the main bios?
Model: HP Elitebook 850 G6
MB SPS: L62758-601
System BIOS: R70 Ver. 01.26.00 10/02/2023
ME Firmware Version: 12.0.93.2331
ME Firmware Mode: Enable
Audio Controller: Realtek ALC3294
Video BIOS Version: Intel(R) GOP Driver [9.0.1085]
Reference Code Revision: 7.0.77.0
Embedded Controller Firmware Version: 52.6F.00
USB Type-C Controller(s) Firmware Version: CCG5:2.5.0
Born On Date: 02/26/2020
SKU Number: 4YD61AV
Universally Unique Identifier (UUID): CAE3150163F5964A5A636D6EB5C74B5C
UUID (standard format): 0115E3CA-F563-4A96-5A63-6D6EB5C74B5C
Build ID: 19WWCFBT601#SUUG#DUUG
Product Family: 103C_5336AN HP EliteBook
System Board ID: 8549
System Board CT Number: PHWHBOOWBD6885
Integrated MAC Address 1: E8-D8-D1-E9-58-04
I'm attaching main bios dump.Attached FilesLeave a comment:
Read the rules before posting
You MUST:[LIST][*]Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.[/LIST -
I need to unlock my bios password please
HP EB 850 G6
thanksAttached FilesLeave a comment:
in first boot press f10 reset to defaults.
use BCU or MPM tool.
if you don't know how to fill those info in bios just upload the EC for Easy unlocking.
Serial Number: 5CG0102W1L
Product Number: 6XD57EA#ABU
CT Number: PHWHB00WBDG1TL
build_id: 19WWCFBT601#SABU#DABU
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPhKhkjhk8.BQ
MAC Address: 38-22-E2-4B-7C-FAAttached FilesLeave a comment:
HP elitebook 850 G6 BIOS UNLOCK
sn:5CG0102W1LAttached FilesLeave a comment:
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
needs to unlock thanks in advanceAttached FilesLast edited by techrecycle; 02-13-2024, 10:11 AM.Leave a comment:
Re: HP Elitebook 850 G6 BIOS UNLOCK
here u goAttached FilesLeave a comment:
Channel: BIOS Requests ONLY!
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by druxHi,
I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
These models have AMI/Aptio BIOS.
Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...-
11-03-2024, 01:18 AM -
by clrscrplease help me unlock bios password hp elitebook 835 G11
S/N: 5CG50434RD
thanks!...-
- Loading...
